Indexing a clutch m...
[Closed] Indexing a clutch mech
6 Users
I've just fitted a clutch mech, and it seems the indexing setup is more sensitive than my old mech, and I'm struggling to get smooth shifts on/off the 36T cog on my cassette. Is this a function of the extra tension from the clutch mech or am I missing something?
Posted : 15/09/2013 7:14 pm
I havent had any more/less problems with setting up a clutch mech. I did make sure I did it with the clutch off when I set it up, no-one recommended this, just seemed like a good idea. (but probably makes no difference)
exactly which mech btw? If it's a Zee maybe you've got the wrong one. (ie you have the narrow range one rather than the wider range) - just a wild guess.
Posted : 15/09/2013 7:17 pm
I doubt the clutch would do anything. Change it to the off position if You want to check. Mine indexed just as my old mech
Posted : 15/09/2013 7:18 pm
I fitted one last week and didn't have any issues at all. Is the clutch engaged while you're indexing? Mine wasn't, I left clutch off, set stoppers, then indexed as usual.
Tested without clutch then with and all good, rode without issue. Maybe I was just lucky!
Sounds like your limit screw is too far in.
Posted : 15/09/2013 7:19 pm
B-tension screw?
Silly question, but you are running 10 speed kit with it aren't you?
Posted : 15/09/2013 7:23 pm
Ok - sounds like its my set-up rather than the clutch mech per se. My rear end needs its bearings replaced too, so ill do that before fine tuning it.
Yes, all 10 spd!!!
Posted : 15/09/2013 7:42 pm
I followed this guide when i built my xc bike up, and worked just as well on my other bike too so obviously wasnt a fluke...
http://bikemagic.com/gear/how-to/mountain-bike-maintenance/rear-mech-set-up.html
Posted : 15/09/2013 7:47 pm
Cheers.
Posted : 15/09/2013 7:54 pm
