increasing rotor si...
increasing rotor sizes....what do i need?
6 Users
Im looking to make my wheelsets more interchangable between my Nukeproof Mega and Reign ebike. The ebike has a 220/200mm front and rear, the Mega 200/180. Both use post mount, both Rock Shox (Zeb and Lyrik) and SRAM Code/Guide brakes. I have rotors, what do i need in the way of adaptors?
Posted : 22/12/2022 2:23 pm
 mert
might need some shims to get the rotors in the same place.
Posted : 22/12/2022 3:18 pm
cheers - will this work on both front and rear?
Posted : 22/12/2022 3:27 pm
Yes. As long as you have a 20 mm adapter, it will space any caliper out 20 mm. 160 mm to 180 mm, 180 to 200, 200 to 220, front or rear, it shouldn't matter.
Posted : 22/12/2022 3:31 pm
This might not quite be correct - it depends what is there already. You don't want to be stacking 2 x +20mm adapters on top of each other!
You might have a +20mm adapter on the forks already, in which case you should be able to move that to the rear (assuming there is no adapter on there) and just need a +40 for the front.
Posted : 22/12/2022 3:33 pm
Yes, you should check what's there already. Good point.
Posted : 22/12/2022 3:35 pm
thols2
Two +20 mm adapters
That would be true of you were just stacking on top of existing adaptors, but not right here.
Zeb has a 200mm post mount, so needs +20 to take a 220mm rotor. Lyrik depending on age is either 160 or 180, so needs +60 or +40 for the same rotor.
Posted : 23/12/2022 12:59 pm
Yes, as tomnavman pointed out, it really needs to be an adapter that is 20 mm larger than whatever's currently there.
Posted : 23/12/2022 1:20 pm
Some thoughts on rotor size from Magura
https://magura.com/en/EUR/Bremse_einbremsen
Posted : 23/12/2022 11:14 pm
https://magura.com/en/EUR/discs
Posted : 23/12/2022 11:15 pm
