If you bust your XT...
[Closed] If you bust your XT 10 speed mech...
9 Users
...would you just get a Zee or another XT?
Posted : 31/03/2016 7:35 pm
Is it short cage you need? (Zee is only available in short cage).
If it is then yes i'd go Zee, if not i'd go SLX.
Posted : 31/03/2016 7:39 pm
11-40 cassette and single chainring, so ???. Thought there was a wide ratio Zee too?
Posted : 31/03/2016 7:43 pm
Won't work with Zee, Wide ratio on see is 36t max.
40t ends up with the mech cage breaking.
Posted : 31/03/2016 7:47 pm
Ok cheers - wasn't sure if the numbers were max cog size or overall range of cassette. SLX then, unless the XT is worth the extra for any functional reason?
Posted : 31/03/2016 7:52 pm
On a 40T cassette a Zee only just works, and thats on a hardtail. The best bet is a mid cage SLX as the different cable arm on the XT offers less clearance for the 40T cog than a SLX, which can lead to clashing chain/mech. XT will work, but in reality the SLX is actually a better mech for the job.
Posted : 31/03/2016 7:57 pm
That's handy, thanks Ben.
Posted : 31/03/2016 8:03 pm
 Rich
I'd get an M8000 XT mech.
There are many accounts of this working great on an 11-40t 10 speed set up, due to it being designed to work with a 40/42t cog.
Slx
Posted : 31/03/2016 8:06 pm
I've run a zee with 11-40t (hope trex) for well over a year on my transition scout. I'm guessing a lot depends on the frame & amount of movement and the setup is critical.
http://singletrackmag.com/forum/topic/zee-mech-freeride-with-hope-t-rex
Posted : 31/03/2016 8:07 pm
I ran a Zee with a 40t Hope extender for a while before it twisted into a ball of metal. Swapped to an new xt M8000 rear mech and its been bloody amazing. Sweet 10spd shifting - so much better
Posted : 31/03/2016 8:12 pm
Rich - Member
I ran this for 8months and it shifted loads better than the 10s XT mech/RAD cage combo I had previously.
Plus if you decide to go 11 speed later, you're already on your way!
Posted : 31/03/2016 8:15 pm
Tempting but twice the price 😕
EDIT That's true though ^
Posted : 31/03/2016 8:17 pm
olibluegoat - Member
How that happen?
Posted : 31/03/2016 8:27 pm
 Rich
£45 from Ebay if ordered within the next 25 minutes.
[url= http://www.ebay.co.uk/itm/Shimano-Deore-XT-M8000-Shadow-Rear-Derailleur-11-Speed-GS-Medium-/311422970288?hash=item48824169b0:g:CKUAAOSwu4BVywnm ]Use with code CUK20.[/url]
Posted : 31/03/2016 8:33 pm
Ah bollocks, serves me right for going to the pub!
Posted : 31/03/2016 9:20 pm
try it anyway. Paypal went down before 10pm so it still worked for me 5 minutes later but is showing as pending.
Posted : 31/03/2016 9:29 pm
