ive just had a pair of brand spanking new 180mm ice tech rotors delivered
all packaged securely and 2 seperate boxes so chances are im missing something
on the tech docs :
it shows the diagram of fitting, which is clear
however on both packages i havent received the 'fixing washer' part?? is this normal? is it only required on different size ones or similar?
ive got the 6bolts and tightening plates, but both seperate packages had no 'fixing washer' in the pack, its not already fixed onto the rotor either
any ideas? surely it cant be that random that two seperate rotors are missing the same part?
This fixing washer isn't used anymore. So don't worry you're not missing them.
phew! thanks chunky....thought it was a bit odd, be nice of shimano to update their site once in a while then
guess you dont have to do the bending thing with the tightening plates anymore then either?
the new tightening plates just say 'top' on them so im guessing thats face up
You can flip them up a little if you want, but I wouldn't bother.
Yeah I think its been noted that Shimano need to update their documentation.
thanks chunky appreciate the info 🙂
