I've just purchased a 1st generation Mojo and I was hoping to slacken out the head angle. It looks like the headset cups are bonded into the carbon meaning I can't fit a Slackerizer- does anyone know if there's a workaround?
Unsure regards the headset situation. But you can go with off set bushing for you rear shock these can give you between 1/1.5 degree slacker and will all so lower the bottom bracket which will not be a bad thing on a bi,e from around 2006 onwards. There's quit a few places do them but burgtec is a good start point once you know what size you need to replace them.
http://www.burgtec.co.uk/products/offset-shock-hardware/burgtec-titanium-offset-shock-hardware/
Kit 7009 ok
Thanks, I'll investigate.
Pooped a link in with code ok
Looking at them there 8mm bo,t so that would be 1degree slacker
I've ordered one! Hopefully i'll notice the difference. 🙂
i used the off-set bushings and put on a 150mm revelation on mine. There was a guy SARS I think his name was that did a custom run on a angleset-type headset for the Mojo, but not anymore.
If nothing else the 8 or so mm drop in bottom bracket height you should notice as it should corner a lot better
