I60mm Pikes and Tre...
[Closed] I60mm Pikes and Trek Remedy
11 Users
Thinking of getting a set of the new Pikes to replace the Fox 32 (150) on my Remedy.
Am toying with getting the 160mm Pikes which would slacken-up the head angle a little, although surely not a huge amount over 150mm Fox's. Think I wouldn't mind a slacker head angle.
Does that sound like it would work? I don't like the flexy 32mm Foxes. Also don't like the linear spring. And the damping is sticky (even after a service).
Also thinking about replacing the Remedy frame with a Commencal Meta SX in the next year, just can't afford to do it all at once. Are the Pike's still suitable for the tougher Meta SX or would Lyriks / Marzocchi 55's be a better fit?
Posted : 31/01/2014 8:06 pm
Rockshox have a naturally higher axle-crown when compared with a same travel Fox fork, so the increase will be more than 10mm
Posted : 31/01/2014 8:33 pm
 LoCo
Ran some 150mm pike 29er on my 26" remedy, with a few other mods ( shortened shock, 650 rear wheel) so lowered BB and head angle at 64 degrees 😉
Posted : 31/01/2014 8:37 pm
Fox 32 26" @ 150mm and QR15 A-C I think is 525mm
RS Pike 26" @ 160mm I think are 542mm
So add another 17mm
Can you get a 26" Pike with 150mm travel?
Posted : 31/01/2014 8:49 pm
I'm running 160mm Slants on my Remedy and they are about a gazillion times better than the Fox 32's
Loco - just out of interest is there much you can do to the DRCV RP2 on the Remedy?
Posted : 31/01/2014 8:51 pm
Hmmn.. 17mm sounds like quite a lot! Maybe I should stick with the 150mm Pikes. Was hoping to get the 160 ones in case I upgrade the frame.
Cheers for the advice guys.
Posted : 31/01/2014 10:17 pm
I could be wrong but I don't think the parts to change them to 160 at a later date will be too expensive from Loco.
Posted : 01/02/2014 6:39 am
I run some 160mm Lyriks on my 26 Remedy. Works fine.
I put a Van RC coil on for the Alps (LoCo supplied the shock). A tad heavy with the std steel spring but works well. TBH I rate the std DRCV air shock though.
Posted : 01/02/2014 7:15 am
I've been running a set of 2012 160 Talas RLC Fit on my 2012 Remedy with no issues and it makes it much better on the rough stuff. The Remedy was originally produced with 160's. Go big my man 😀
Posted : 01/02/2014 8:45 am
Sounds like a plan!
Hadn't occurred to me that you can reduce the travel by swapping the airspring pushrod. But googling for that specifically comes up with a few useful threads. Apparently the uppers and lowers are the same across all travel lengths and wheel sizes.
Thanks for the help 🙂
Posted : 01/02/2014 9:50 am
Just give it a go. Sticking 170mm forks on my 150mm Enduro has slackened the HA off to 65.5 deg from 67 and it rides lovely
Posted : 01/02/2014 11:37 am
campfreddie - Member
It's not quite that simple, Fox are all over the place- so frinstance new Pikes are longer than 32s but shorter than 36s.
Posted : 01/02/2014 3:05 pm
I've swapped my Fox 32 150mm forks to the Dual Position Pikes, 160 /130. Not really noticed the height difference at 160mm, I just dropped one spacer out from under my stem. Climbing is better at 130mm.
The Pikes will give you far superior tracking and damping, in fact they take some getting used to as any side to side movement your wheels find will all come up back to your bars (this is a good thing) unlike the Fox forks which twist to dampen it a bit, if you see what I mean. Go for the upgrade and let us know how you get on !
Posted : 01/02/2014 6:02 pm
