So, I've gone 1x10. It hurts at the moment but I like it. I think the only reason it hurts is the lack of riding over the last month due to being away and the bike being broken (I never used the granny ring before, and I have a better gearing range now).
Those clutch mechs are truly fantastic. The new 10-speed XT stuff feels way nicer than the old XT stuff it replaced.
At the moment I've left my front-mech on as a top-guide and with a clutch mech it seems more than enough to keep the chain in place, didn't drop it once on Sundays ride, when I was dropping a couple of times every ride before.
So, what chain guide would you recommend. I have a 35-tooth chain ring ATM, and am considering getting a bash on their as well, but 100% sure yet on that one.
The guide need to be either a BB mount or mount in the place of my front-mech as my '08 Meta5 doesn't have an ISCG tabs.
The Superstar one is adequate, but the MRP and e.13 are better quality. Having used all three, I personally prefer the MRP (haven't used the latest one though). It's stiff and has a little more adjustment than the others.
A lot of other companies seem to be doing them too nowadays, but a lot seem to be rebadged variations on the Superstar one.
I'd prefer to avoid superstar, last chain guide from them caused me more issues than not having one so I'll take a look at the MRP ones, thanks.
What are your thoughts on a full guide vs. top only for an AM rig with a clutch mech? Necessary to have a full guide, or would you run just a top guide?
I had a similar question not so long ago...
Last post tells you I went for a pair of BBG bashrings, so far, so good.
I really like the MRP 1X- light, and easy to set up. I've got a Superstar one and it's OK, but I'd not buy another since really good products aren't that much more expensive.
I get on fine with just the clutch and top guide on the ragley, not sure if it'd work as well if you add chain growth etc from a full suss though but it's been ridden plenty hard, no bother.
I've been running a 1x10 for a fair while on my hardtail. Running a zee mech with a LG1+ up front; what i loved most was how quiet it was.
I recently bought a Giant trance and run a zee mech with a superstar components top guide. I've given it a good scram over the last couple of weekends and too my surprise ive yet to drop a chain! My only issue thus far is chain flap...even with the clucth mech im still getting a rattle and flap from the chain. Not as bad as a non clucth setup, just not as good as clutch + full chainguide. I'm putting it down to the lack of lower roller so just ordered a bionicon C-guide to see if it helps.
I had a fair bit of chain flap when I fotted a clutch mech - shortened the chain, problem solved.
MRP G2SL
[img][url= http://farm9.staticflickr.com/8238/8493712714_d6a6e6bb5b.jp g" target="_blank">http://farm9.staticflickr.com/8238/8493712714_d6a6e6bb5b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/66541880@N03/8493712714/ ]Cotic Rocket[/url] by [url= http://www.flickr.com/people/66541880@N03/ ]passtherizla[/url], on Flickr[/img]
Don't use the C-guide with the clutch enabled - the tension will rip it off.
Are you speaking from experience?
I know of one other person runnin with cluch mech on amnd read a couple reveiws of guys running the same setup with no issues!
Thanks everyone.
Looks good, ideal if I decide a top only is the way foreword.
So based on this you don't think I'd need a lower roller as well as an upper guide?
[...]not sure if it'd work as well if you add chain growth etc from a full suss though[...]
Exactly what I'm worried about by going for a top-only guide.
MRP G2SL
Looks smart, thanks for the picture. Looks like a good bet if I decide to go for a full guide.
Wouldn't work on the meta5 anyway due to the design of the swingarm.
I guess the main question now I have a few product recommendations for top only and a full guide, will I be likely to have any issues when I hit rougher terrain with a top-only guide, baring in mind that chain will grown with it being a full-suss.
See how you go with the front mech on for now, before deciding if you need a bottom guide too?
I made my 1x10 debut yesterday, with a MRP x1 guide and XT clutch mech on a hardtail.
Shrugged off the bumpiest terrain Rivington has to offer so I'm happy with it.
Blackspire EinfachX
Are you speaking from experience?I know of one other person runnin with cluch mech on amnd read a couple reveiws of guys running the same setup with no issues!
No, admittedly I was just paraphrasing Bionics' recommendation. If real world experience shows that it's work, great, don't mind me. 🙂
I've got an e13 XCX (I.e. top mount only) coupled with a Shimano Shadow + mech, have had it for a few months now and I'm impressed. I've not lost the chain yet. FWIW I don't think a front mech fixed in one position is comparable - the XCX is much narrower and surrounds the chain far better (it doesn't need to move / clear the chainring). This is on my 5" full sus XC bike by the way, and I ride in the peaks so it's definitely rocky enough for a decent test. On a DH bike I'd probably still go for a bottom guide for added security but I just don't think you need it for XC / All mountain / whatever you want to call it.
The main issue is that you can't run a bashring with this setup (the chain device gets in the way) although you could use a BB-mounted taco device. I haven't bothered - it sounds stupid but the chain is always protecting the chainring (unlike if you're using 2x or 3x) so the odd rock strike isn't really an issue. I used to use 2x10 with a bash for years and my old bashring is covered in marks (I used to ride trials so I wasn't exactly shy about hitting it). My feeling is that I'll probably wear out the chain and replace it before rock damage becomes an issue.
MRP have a new one that's top guide and taco. Called the AMG, I think. I was all excited until I saw the inevitable price: double the price cos it's got double the plastic.
danielgroves - MemberSo based on this you don't think I'd need a lower roller as well as an upper guide?
You might not, but either way, shortening the chain is a cheap thing to try out.
As far as guides go, I have the MRP Lopes on two bikes, and it's great.
warpcow - MemberMRP have a new one that's top guide and taco. Called the AMG, I think. I was all excited until I saw the inevitable price: double the price cos it's got double the plastic.
Some very cheap MRP AMGs on EBay, if they're still about.
Anyone successfully running just a Shadow+ without a guide?
I've set mine up with a unramped 36t and an XT Shadow+ with chain as short as possible. Only had two rides so far and everything seems spot on and unlikely to be going anywhere...so far!
Not got to ride anywhere really rocky yet but done a few jumps and stuff without dropping.
Wondering whether anyone else has stayed guide less..
Personally I wouldn't be without a lower guide (I only have a standard XT rear mech no no clutch to compare experience of). I had a MRP G2SL and thought it a little overkill for my riding so swapped it for a MRP Lopes. Both fantastic and very quiet in operation.
Been running XTR shadow + with e-13 XCX on my Blur for a few months now no dropped chain ridden 2-4 times a week, had an MRp x 1 on an 80mm travel 29er with xtr shadow + mech dropped the chain a couple of times, don't know why same cranks chain ring etc
The new Hope stuff looks nice!
RDL-82 - MemberAnyone successfully running just a Shadow+ without a guide?
I tried for a little while, didn't really work for me at all (E13 ring and XT clutch)
Northwind - Member
See how it goes then I guess, when I get out there properly again.
You seen the price of that stuff?
Sounds good, shall look at one of those then, thanks!
I wouldn't have before but given how much stiffer the clutch mechs are…
I have a hope guide on my trance with an xtr clutch mech. It works flawlessly and is so much neater and better looking than the ugly bulky guides like the mrp and e.13. But the using the hope does mean you need a bash ring. I have an e.13 xcx on my cove and again it works perfectly its just compared to the hope its huge. I honestly believe that some of these guides are massively over complicated with tolerances that are too tight to stop rubbing across the whole range. Just think how much clearance there is around the chain when using a front mech. I also have a Paul's chain keeper on my anthem and again its such a simple way of stopping the chain coming off that I wouldn't consider the e.13 xcx type again.
I have some photos of all 3 if you want to see them. Not sure how to post them up on here though.
Andy
Hope:
[URL= http://i.imgur.com/1VJU5PE.jp g" target="_blank">http://i.imgur.com/1VJU5PE.jp g"/> [/IMG][/URL]
Or pauls...
andysredmini - Pictures would be appreciated, I like my bikes to look pretty, and it's always better to see one mounted 😛
tomcanbefound - That hope one sure does look pretty, kinda coming round to spending the extra cash now…
Hope does look pretty.
My experience -
Short cage x9 mech + Gamut P20S - quiet, low friction, never lost the chain
Zee clutch mech + Gamut P20S - Zero noise, lots and lots of drag
MRP 1x + zee clutch mech - lots of noise, i could make the chain fall off, but doubt it would actually fall off in normal use
MRP 1x + zee clutch + C.Guide - back to quiet, no chain loss, nice and free running
My lessons learned -
.Clutch mechs do make things quiet but cause an awful lot of drag with a full guide
.clutch + top guide is more noisy than full guide and normal mech
.clutch + top guide isnt enough to be 100% the chain isn't coming off
.clutch + c.guide works with no issues on 1x if set up just to guide the chain rather than tension it
I'll be doing something similar this summer (1x10 with Zee clutch mech and wanting to run a bashguard). Your options are either to run a full guide with the lower part removed if you don't want it (SRS+ unbolts, LG1+ or G2 needs to be filed off), or Hope's guide (using their integrated bashguard/chainring as shown above if you want the slickest solution).
I have an SRS+ already which I'll probably use but if I have a bit of cash to spend then I might splash out on the Hope.
DeanFBM - I don't see how the clutch thingy can result in extra drag - chain device or no chain device?
Probably to do with keeping the chain tighter against the lower guide slider, creating more resistance?
I noticed when changing nothing but the mech an increase in drag when leaving the bike in the stand, not something I notice on the trail though.
Me neither, but it is my experience that it makes more noise too (with top guide only).
Superficial - i didnt really get it either, had me massing around with guide alignment for a bit. The clutch doesn't much any more tension on the chain, it merely prevents the lower arm rotating.
danielgroves
Just sent you an email with some pics.
Post them up if you want. I cant work out how to do it.
Andy
Thanks again everyone.
After looking through the pictures andysredmini sent I'll probably go down the hope route. Like the minimalism of it.
If anyone want me to upload the pictures Andy sent me just shout and I'll do so.
Yeah I wouldn't mind, the Hopes a possible route I'll take.
I hadn't realised the Gamut device you're using was one of those ones with a slider rather than a sprocket. I suppose that makes more sense as the mech would be pulling down harder onto the slider bit.
My experience -Short cage x9 mech + Gamut P20S - quiet, low friction, never lost the chain
MRP 1x + zee clutch + C.Guide - back to quiet, no chain loss, nice and free runningMy lessons learned -
Pretty much same as me, was happy with full guide (SS plasma) no noticable drag, quiet and never dropped a chain.
Now running top guide with zee on my new trance build, havnt dropped a chain but the noise and chain flap is doing my head in!! Hopefully the c-guide that ive ordered does the trick 🙂
Very busy at work today, so I'll do it when I get a minute. May have to be this evening though.
I don't get any chain noise at all with Zee and bash+jump stop. I'm on a hardtail though, so maybe the lack of chain growth is what makes the difference?
I'm running 1 x 10 on both bikes, neither of which has ISCG so had to go with one seat tube mounted options and one BB mount.
Seat Tube Mount is E13 XCX-great
BB Is the newish AMg By MRP-only a few hours done with it but so far great also.
I run a single ring on both of my bikes, one 10 speed and one nine speed.
The SX as a medium cage none clutch X9 10 speed mech, 11-36 tooth cassette, 34 tooth ring and an E13 LG1 Trail chain device.
The BFe has an older 9 speed X9 mech, 11-26 tooth cassette, 36 tooth ring and a Superstar Plasma chain device.
If I'm honest I fail to see why the E13 is twice the price of the Superstar version, it's not as sturdy and is noisier, despite being set up as per the instructions. Both seem to work and keep my chain on and make cleaning easy with no bash guard.
I really struggle to get my head around the cost if chain devices because you get less for your money than before. The MRP System 3 was £100 and all metal and included a bash guard. My E13 has less bits and is mostly plastic but costs £15 more and is noisier.
