Anyone know a good stem mount for an i phone without spending a fortune !,as all the ones ive seen arent cheap !!,i'd prefer stem mount rather a bar clamped one..
Endomondo do one.. but not cheep either...
I've got the Topeak one (around £18 i think) and use it (only occasionally) on the stem and it's been fine. Only annoyance is that Topeak insist on putting a sprung belt clip on the back of all their products (does anybody put a phone on their belt anymore??) which rattles as soon as you hit anything but the smoothest tarmac. I just wedged a bit of old foam into mine and it made it silent. It's waterproof as well and is easy to use through the clear plastic cover.
My brother in law has one of [url= http://www.thinkbiologic.com/products/bike-mount-iphone-4 ]these[/url] and loves it.
I've got one of [url= http://www.ebay.co.uk/itm/Handlebar-Mount-Waterproof-Case-HTC-Wildfire-/120646603053 ]these[/url] for my HTC wildfire and its surprisingly sturdy, but I need to set about the clamp with a file to make it fit the stem.
Is it wise to strap a £400+ phone to your bars? Fine if you're doing a nice leisurely pootle but I don't think it would survive a crash. Fair enough if it's insured but still a ballache if you break it.
I strapped my iPhone to my stem using the Topeak one and promptly fell off on ice smacking the bike into the concrete. I was broken, the bike was broken, but iPhone was fine. I don't think its any more likely to get broken than any other expensive bits, such as fork stanchions or frame etc.
Agree with the topeak one being a bit rattly. Also you can't make phone calls without removing it from the case or using a bluetooth headset. i think the more expensive ones allow you to still use the dock connector for keeping it charged up via a dynamo hub or external battery as well.
I should say, my Wildfire is a £50 secondhand phone with no sim card or network coverage, I use it purely as a GPS with MMTracker.
My actual phone is securely in my rucsac.
Tigra iPhone mount here. £25ish from Wooly hat Shop on eBay. £40 in Apple Store. Kept phone dry in the rain and didn't fall off the bars. Can be bar or stem mounted and rotated portrait/landscape and QR'd off when you stop. The screen still works through the cover. 🙂
