I just can't k...
[Closed] I just can't keep it up (my seat post)
10 Users
my seat just seems to get lower over a couple of rides, mainly on smooth trails. Any one recommend a good one preferably quick release. Hopefully I can keep it up 😉
FYI bike is a Genesis Mantle (27.2mm seat post)
Posted : 02/05/2013 11:54 am
Salsa
not hope! if you want it tight
Posted : 02/05/2013 11:59 am
Try carbon assembly paste (even if neither post nor frame are carbon)... it is gritty to give the post better grip.
Dave
Posted : 02/05/2013 12:02 pm
Not had any issues with hope tbh, but salsa are good. How worn is the post on the shaft?
Posted : 02/05/2013 12:07 pm
Ye I agree, any grease with a gritty texture, I think the one I used just have been the carbon assembly paste as mentioned above.
I had a nightmare with mine, orange r8 frame, Thomson seatpost and stock QR so used some of that grease and fitted a hope bolt clamp and now it's tighter than a nuns ....
Posted : 02/05/2013 12:08 pm
carbon paste,
new clamp
oversize post (ragley make 27.3 for this issue)
in that order.
Posted : 02/05/2013 12:10 pm
carbon assembly paste has just fixed mine (ali frame & post for ref), which was dropping a cm every couple of miles.
Posted : 02/05/2013 12:19 pm
thanks for suggestions, just ordered some paste. hopefully all will be good.
Posted : 02/05/2013 2:06 pm
If using a qr clamp grease the qr cam. Then when you're closing the lever you're applying clamping force rather than over coming friction with the cam.
Posted : 02/05/2013 2:21 pm
Not really linked to the seatpost issue, but what do you think of your Mantle?
I'm looking to replace my stolen Boardman & quite like the look of the Mantle 20. Never ridden a 29er, but love my Genesis CDF 'cross bike.
Doesn't seem to be any reviews online yet
Posted : 29/05/2013 4:31 pm
Posted : 29/05/2013 4:49 pm
generally I am loving the Mantle, though I haven't ridden any other 29er's to compare with it just feels right and sorted, it seems to eat up the woodland trails where I live. The only negative so far are the stock tires are 2 wide and there wasn't much clearance, I changed to raceking 2.0 tires problem sorted.
BTW assembly paste sorted the seatpost issue out.
Posted : 30/05/2013 7:58 pm
Carbon paste and a Syntace Superlock quick release. Has a rubber seal to keep the worst of the muck out too, works well enough to stop the anodising wearing off the post 🙂
Posted : 30/05/2013 8:08 pm
