I dont really know why but it seemed too good a chance to miss
Bought a couple of Hope vision 4`s with out working batteries so wondered what it would be like if I converted one to 15 volts and so could run the 4 new XML U3 Leds I installed in it at the full 3 amps .
just got it finished and waiting for nightfall to see if it is an improvement Mad yes 😈
Was fair hoping it was mine there!!
[i]waiting for [s]nightfall[/s] [b]the purple spots to go away[/b] to see if it is an improvement[/i]
ftfy
Jonny Yours is on the bench waiting for some glue to dry should be in the post tomorrow all being well
I'll keep my eyes open in Cumbria tonight and see if I can see the sky lit up towards Yorkshire way!
Really pleased with my Hope Vision 2 conversion, easily out performs my MaaxD, brighter and better pattern. Don't need to use it on flat out, so far got 90 mins out of the 'double' Hope battery any ideas what I can expect on run time or is it trial and error?
Think you may have a few more on the way now my mates have seen this one.
Cheers!!
I was hoping that you'd really meant to write 'Exposure Maxx' instead of 'Hope vision 4' 😉
For those summer rides when the sun just isn't bright enough, choose Trout.
Trout are you able / have you ever upgraded any Maxx D 's ?
Is it possible ?
Is there any decent upgrade that can be done with a hope vision one?
Hmm, ain't gonna be no darkness over Englandshire tonight then
Best you take a fire extinguisher with you for the grass, trees, buildings, towns, people that'll spontaneously burst into flames when you turn that on!
Shredder I have an exposure in the queue to be looked at so not sure yet
MuppetWrangler Not been inside a Vision 1 so cant say what can be done.
wondered why that bloke was holding a steering wheel to start with.
Thought it was part of an elaborate 'It's driving me nuts' joke.
Impressive. Has that tree trunk got a permanent glow now?
no point turning the clocks back..
hope the dog can still see!
What's the run time like?
is this why New York has power cuts?
you vaporised the dog!!!
Nice!
Trout, I've had a look inside my vision 4 with a view to upgrading to 4No. U2 or now U3s.
I notice that the existing LEDs are all on one board, and they sit on little raised points in the casing.
When you upgrade to T6's, do you use a single star with 4 emitters on, or do you stick 4 single ones in?
What size stars are you using? My rough measurements are that 20mm stars would fit in quite well butted up to each other, so that would just be a case of ensuring that each emitter is on one of the raised bits of the casing?
How long till it overheats?
mrjmt
below is a thread trout started about rebuilding the R4 with XML LED's
http://singletrackmag.com/forum/topic/hope-vision-de-re-constructed
hope this gives you the info you were looking for.
Rusty
Good god!!!! Think I might have just been inspired for a new winter project........ 🙂
Pahhhhh, frankly that's just amature.
34000 lumens (there's 48 x 1100lumen LED's so presumably either it got hot and they had to drop it a bit or they've actualy measured that!)
www.youtube.com/watch?v=85wrLS_heKA
mrjmtbelow is a thread trout started about rebuilding the R4 with XML LED's
Rusty
Thats exactly what I was looking for, and have been for months!
Thanks a lot matey! 😀
Footflaps
It will never overheat cos the driver keeps tabs on the temp and when it hits 60c it dims until it cools down a bit
this happens in about 3 minutes on the desk on full not yet tried it on the bike
Thinking about making upgrade availabe to us mere mortals? I presume it Will piss all over junkyards 2000odd lumen he just got off you 🙂
Donk Yes will do send in your hope and I will hop it up to this spec
but it would mean a new battery
First ride with it this morning with the Lumen hound
and ran it for 10 minutes at Paddy speed without it dimming down though it was warm to touch and dimmed within 2 minutes of stopping
lol @ the soundtrack 🙂 Loved the Darth Vader intro.
Did the people in the boats start getting up because the sun was rising?
I recognised the voice at the beginning, have you been ringing my missus?., lol..
