Hydraulic brake hos...
[Closed] Hydraulic brake hose help
3 Users
I've got my first bike with hydraulic brakes (Diverge). The hoses seem to have some kind of connector in the middle. I can't seem to find anything about this in the internet.
Is it likely that I can reuse this ? I want to lengthen the hose run (I've fitted wider bars and it's too tight). Putting all new hose in looks hard - they go through the frame.
Any wisdom out there on this ?
Thanks
Posted : 12/12/2015 9:58 am
Which diverge is it you have flap jack? Carbon,smartweld or a1?
Posted : 12/12/2015 10:01 am
Carbon...
It looks like it allows the manufacture of the frame and the bars to be separately, then joined together at the final assembly (bike shop ?) phase.
Posted : 12/12/2015 10:21 am
Only asked as typically I've fannied about with the smartweld and a1s, no experience of the carbon one.
Can't see how you'd get a hose union through the frame though, popping up to my local shop shortly and will ask in there. They've sold a good few of the carbon versions.
Posted : 12/12/2015 2:15 pm
Flap jack,once the olives are removed there shouldn't be anything to stop the hoses pulling through, bear in mind that the routing around the bottom bracket may be a bit tight.
Posted : 12/12/2015 3:40 pm
You can get the instructions for the quick fit connectors
Pulling the hose through the frame is pretty easy, I didn't have any problems with mine.
Posted : 12/12/2015 4:15 pm
Many thanks. 'Easy hose joint system'. That download explains all. 😀
Posted : 12/12/2015 4:36 pm
