Hi
Does anyone have one of these I could borrow for a couple of days to shorten my rear cable ?
Or similarly any advice of a cheap one or alternative I could use for a one off use ?
cheers Chris
This, but will take a week to come
If no one can help you I’ll post you mine to borrow but I’m in Northern Ireland so 2 days to get to you, email in profile if your stuck
Any normal (gear) cable cutter will work absolutely fine.
Just use a sharp knife.
Yep I just used gear cable cutters on mine, worked fine. Assume they're not braided. If you're in a bind you can always pop down the local screwfix and grab some cheap cable cutters.
Works for me as well.
Get this one tomorrow if you have prime
https://www.amazon.co.uk/Jagwire-Spaceage-Hydraulic-Hose-Cutter/dp/B01MFGZDWJ
Or epic bleed solutions do one for a fiver.
I got one I’m in Bredon. So not a million miles away, won’t cut metal braided cables kind it’s one of these:
https://www.epicbleedsolutions.com/products/tools/brake-hose-cutter/
If its not braided, this will work fine, its what I use. At that price its not worth borrowing one 🙂
