Hunt front hub slop
[Closed] Hunt front hub slop
5 Users
My front Hunt Endurowide hub seems to have a lot of side to side slop/rattle unless I really crank up the axle, almost like the tolerance is a mm or so off.
Had a look at the bearings, they seem smooth and normal. Had a look at the axle, looks usual.
Anyone got a similar issue?
Fork is a CC Helm, for reference.
Posted : 10/02/2022 7:31 am
 DanW
Ask Hunt direct- their support is fantastic
Posted : 10/02/2022 10:37 am
Just the bearings going. I realised my rear Hope Pro 2 hub had developed the tell tale sideways shimmy this morning as I was about to set off on a local ride. Only seven years since I last changed them - damn Hope and their shoddy products!
Posted : 10/02/2022 1:47 pm
New or used? If it’s new, give em a shout. If it’s old, whack some new bearings in
Posted : 10/02/2022 3:01 pm
Is this new? Then there is a problem. Thru axles if everything is square and not bent/mangled, shouldn't need much at all to hold them in place, many customers kill their hubs by tightening the absolute hell out of them.
If its more than about 3 months old bearings probably failed due to 1) they aren't very good in UK climate 2) you wash your bike too much/aggressively 3) "hunt"/bitex hub tolerance is a bit variable. Literally fed up with the number of new hunt's that the barrel of the hub body or freehub is too tight = premature bearing failure, hard to get out, hard to get new ones in square despite 25 years experience at this! and then new bearing feels shite = they have a tolerance or QC problem.
This isn't slamming that company as a whole, just a note that they more than most, have tolerance issues. Loads of folk happy with their hoops.
Posted : 10/02/2022 3:17 pm
Cheers guys. Yeah, they're not new, just after being used to the service life of Hope hubs (have I ever changed the front hub bearings in my Pro 2 in the 12 years I've had it?) thought I might be doing something daft. I've got some spare bearings kicking about so I'll Bob them in. Thanks 🙂
Posted : 10/02/2022 4:22 pm
Put some quality bearings in and you’ll have the same service life as a Hope hub
Posted : 10/02/2022 4:38 pm
