Humour me! gear rat...
[Closed] Humour me! gear ratios and comparisons
6 Users
I have on my bike packing bike at the minute 11/42 with a  30T up front its on its last legs so considering 11/46 with a 32T now thinking 32  for a bit move varvar vroom on the flat how does the top gear compare when climbing easier on the 30 or 32  not a gear ratio wizard so any useful insight would be good
Posted : 13/03/2018 9:16 pm
http://ritzelrechner.de/
Compare both setups side to side, all will become clear.
Also consider an oval ring - I reckon worth half a chainring size at either end in terms of effort.
http://ritzelrechner.de/?GR=DERS&KB=30&RZ=11,13,15,17,19,21,24,28,32,36,42&UF=2240&TF=90&SL=2.6&UN=KMH&GR2=DERS&KB2=32&RZ2=11,13,15,18,21,24,28,32,36,40,46&UF2=2240
There you go - a bit easier in the big sprocket and obviously a bit faster at the other end.
Posted : 13/03/2018 9:23 pm
32/46 0.696 so easier gear
Posted : 13/03/2018 9:26 pm
Cheers 🙂
Posted : 13/03/2018 9:38 pm
Have a look at a Sunrace 46t cassette, less of a final jump between gears than Shimano.
Posted : 13/03/2018 9:45 pm
Pondered the Sunrace option Scuff but heard of problems when back peddling and low on stock in the normal outlets!
Posted : 13/03/2018 9:47 pm
What wheel size?
Ratios are sort of meaningless in isolation...
Posted : 13/03/2018 9:57 pm
29 plus up front 😉
27.5 plus in the rear 🙂
Posted : 13/03/2018 10:03 pm
Ratios are sort of meaningless in isolation…
If it's the same bike and just a swap it doesn't matter
Posted : 13/03/2018 10:06 pm
Have you got clearance for the bigger ring. On my longitude I have to space the ring over so far to get a decent chain line that a 34 or 34 oval won't fit!
Posted : 14/03/2018 9:22 am
