I have a Progresscycles Turbine rear hub - [url= http://www.progresscycles.com/bujes/turbine-disc-tras-uk.html ](this one)[/url], and I'm struggling to find information on what size of cartridge bearings it takes.
Does anyone out there know? Failing that,how do you measure/work this out? I assume the width/diameter is relevant...?
Many thanks.
A quick look at their website/catalogue shows they are a standard sealed bearing but not what size. They should have an i.d. on them somewhere,probably embossed on the seal,such as 6302RS.
Failing that, you'll need the external diameter, internal diameter & thickness measurements.
