HT2 BB shims/spacer...
[Closed] HT2 BB shims/spacers narrower than the standard 2.5mm ones?
4 Users
Anyone seen shims for HT2 type axles? I have a Raceface chainset on which the spline tapers wore out - they're fine if you narrow the BB and tighten them up so that they bottom out but that means there's some side to side play. I just need some 0.5mm or similar shims to replace one of the 2.5mm spacers so that I can get it just right. Or shims to use on the axle (so 24mm ID) which I guess would achieve the same.
Posted : 11/08/2014 1:41 pm
Cassette spacers work on HT2 BBs.
Posted : 11/08/2014 1:52 pm
Still a bit wide though - I need to be able to fine tune the number of washers between 0 and 2.5mm - I'm reckoning 0.5mm shims would be about right.
Posted : 11/08/2014 2:00 pm
If you can get hold of some shims that come with BB mounted chain devices like the e13 xcx they tend to be thinner.
Posted : 11/08/2014 2:08 pm
Ah, that's a good idea.
Posted : 11/08/2014 2:09 pm
Hope do a 1mm one.
I also got a metal spacer that is about 0.5mm thick with a PF30 BB kit. Don't know if they are available separately though.
Posted : 11/08/2014 2:17 pm
I guess I could be lucky with a 1mm spacer. Or maybe I could sand one down to 0.5mm
Posted : 11/08/2014 2:22 pm
