So, I'm after some new bars for my Meta5. I currently have 680mm Easton EA50 bars, but feel like they are too narrow. The question is, how wide to go though? I ride a good XC/Trail/AM mix.
I quite like the look for the Nukeproof Warhead bars, but even these come in 760mm or 800mm. These are to go on a Commencal Meta5, with a 70mm stem which I quite like the length of.
I got some 780s from Superstar and experimented with grip positions,then ended up cutting them down to 740mm,used to use 660s,these feel a lot better.
I have the Warhead bars but ended up cutting them down to about 730mm and they feel great. 760 was too much for me.
I went from 680 too 780 and I prefer the 780 alot more. But I do have less rise on the 780s.
I have used from 500-880 too. I would factor in the type of bike and your setup before you buy a new bar. Also go to your lbs and get the feel of a few bars for width.
Also worth adding. I reduced my stem length from 80-50mm and it just spread me out a bit instead of stretching me out wider.
So it sounds like the Warheads at 760mm could be a good option, and then trim them if I find them a little too wide.
760's feel good
[url= http://farm9.staticflickr.com/8487/8155313455_e3e137c6c9_b.jp g" target="_blank">http://farm9.staticflickr.com/8487/8155313455_e3e137c6c9_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/rocketdog/8155313455/ ]view from the bars 2[/url] by [url= http://www.flickr.com/people/rocketdog/ ]rOcKeTdOgUk[/url], on Flickr
[url= http://farm8.staticflickr.com/7265/8153057192_dd15ddbc7f_b.jp g" target="_blank">http://farm8.staticflickr.com/7265/8153057192_dd15ddbc7f_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/rocketdog/8153057192/ ]Pegasus[/url] by [url= http://www.flickr.com/people/rocketdog/ ]rOcKeTdOgUk[/url], on Flickr
I recently went from 720 to 785. Have cut them down to 765 but worlds apart from how the bike used to ride. IMO the wider the better.
