How to tell if an a...
[Closed] How to tell if an air shock is the correct stroke length
2 Users
I have just spotted my Rock Shox Monarch I received back from warranty has the wrong size written on the Damper Body (the bit that moves in and out of the air can). It has 200 x 51 on it rather than the correct 200 x 57. They replaced the damper body as part of a service. Is there any way of checking that the stoke is the correct one by measuring? The distance from where it enters the air can to the shock bush eyelet is the same as on a shock I know to be a correct 200 x 57.
Posted : 10/08/2013 9:32 am
Put a zip tie round the shaft, Let the air out.. and sit on it..
Posted : 10/08/2013 9:39 am
Cheers will try later.
Posted : 10/08/2013 10:59 am
