How to store a bike...
[Closed] How to store a bike with the front wheel off..?
14 Users
Evening folks, bit of a daft question for your Saturday night! Can't fit my bike in the shed with both wheels fitted, so I need to find a way of storing it 'nicely', as I've just put a pair of brand new Fox 36's on and don't want to mangle the bottom of them. Thought about just putting a cloth or something underneath them, but it's not a sturdy solution so it's not ideal. Any suggestions? Or cheap solutions? It's a concrete floor btw.
Cheers all
Posted : 22/07/2017 10:16 pm
Can you bolt a fork mount to the floor (or wall)?
Like a seasucker mount.
Posted : 22/07/2017 10:26 pm
Can you hang it by the saddle from a beam?
Posted : 22/07/2017 10:28 pm
Not a good idea if it's got a dropper!
Fork mount on the wall is probably what I'd look at.
Posted : 23/07/2017 12:22 am
Absolutely not an issue if it's fully extended. Beware of the internet.
Handy with a grinder and Mig or know someone who is?
You basically need to make one of theseLook at this on eBay http://www.ebay.com.au/itm/252118159421
Cheapest way probably involves finding someone with a knackered old front hub, stripping the spokey and rim-y bits of it, and using some metal strapping over the top to secure it to a bit of wood.
Posted : 23/07/2017 5:44 am
assume being a new Fox it'll be bolt through of some sort. How about a bit of timber of appropriate width (so 100mm probably) with a sufficiently sized hole bored through it that you can secure to the floor (or leave long enough to keep it stable) that can act as a dummy front hub - offer the fork up to it, axle through, do it up.
If you want to be fancy a bit of tubing (curtain pole maybe) as a bushing so the axle doesn't get splinters 😉
Posted : 23/07/2017 6:18 am
I have a loop of string hanging off a shelf at about head height in the cupboard at the end of my hall that I hang the bolt through axle off (flat not a house so no shed or similar).
Posted : 23/07/2017 7:14 am
[url= https://activesport.co/epages/80c85f8f-7a95-4b1c-9c30-e64b314f3f2e.mobile/?Locale=en_GB&ObjectPath=/Shops/80c85f8f-7a95-4b1c-9c30-e64b314f3f2e/Products/BH6002-FT&ViewAction=ViewProductViaPortal&gclid=Cj0KCQjwktHLBRDsARIsAFBSb6wAy3h2djVseRF59UGT1o5M9MgEt1qscK0FHTmPsZG4KrHGnIPgs8waArqJEALw_wcB ]Delta Bike Hitch Thru Axle 20mm and 15mm[/url]
I've been wanting to get one of theses to attach to a piece of wood for the car. But after thinking about it, I could make one on my mill and use hope hub adaptors to get the different axle sizes.
Posted : 23/07/2017 7:26 am
The best option is to keep the bike in the house, not a shed.
Posted : 23/07/2017 7:37 am
Very easy solution - bit off pipe lagging over the end. Not secure but it'll stop damage certainly.
Otherwise the above idea with the wood is probably a good diy option.
Or get one of those crank stands if it'll fit.
[url= https://www.tredz.co.uk/.Gear-Up-Crank-It-Up-Stand-Single-Bike-Stand_62305.htm?sku=182536&utm_source=google&utm_medium=cpc&utm_campaign=google_shopping&gclid=EAIaIQobChMI_rfQvfWe1QIVxp3tCh1t2AowEAQYASABEgIF8vD_BwE ]other options are doubtless available and probably cheaper[/url]
Posted : 23/07/2017 7:49 am
I'd either put pipe lagging over the legs, perhaps secured at the right width to a large foam base; block of that hard white closed cell stuff.
Or get a suitably sized wooden dowel that will work as a replacement axle and make a couple of upstands for the dowel to sit across...
Posted : 23/07/2017 9:09 am
Put a pair of babies boots on the end of each lower 😆
[url= https://m.fr.aliexpress.com/s/item/32785738373.html?spm=a2g0n.search-cache.0.0.12d8732cRy8Gwg ]https://m.fr.aliexpress.com/s/item/32785738373.html?spm=a2g0n.search-cache.0.0.12d8732cRy8Gwg[/url]
Posted : 23/07/2017 9:27 am
I'd secure a couple of hooks to the wall about 80mm apart, and hang the bike vertically from the fork axle, two main reasons:
1- you can claim back some floor space.
2- you'll have to re-fit the axle to store the bike, if it's already fitted you are less likely to to forget it when chucking the bike in the car...
You can still fit a ground anchor and loop chains and cables through the wheels/frame to slow down thieves.
Posted : 23/07/2017 9:32 am
That's what I had understood until a few weeks ago when I was persuaded by several of this parish I'd been wrong for years. I queried and no one contradicted so I assumed I was wrong. Beware indeed! I'll go back to my default behaviour then. 🙂
Posted : 23/07/2017 10:55 am
Also true. I'm amazed how many people appear to keep expensive bikes in wooden sheds. Obviously thieves shouldn't exist, but we all know they do...
Posted : 23/07/2017 10:59 am
I'm amazed how many people can't understand how some people simply can't fit bikes in their houses...
Posted : 23/07/2017 1:20 pm
I'm amazed at how many people don't swap their new shiny bike and wife around..wife in the shed, bike in the bedroom
Posted : 23/07/2017 7:29 pm
Goldigger - Member
Your bike cooks, cleans and brings freshly poured ice cold beverages to you whilst you watch the tdf highlights?
Posted : 23/07/2017 8:16 pm
