Off to Fort William tomorrow to ride in the no fuss Tour de Ben Nevis on Saturday. Amazing course, I did (slowly!) it last year but the hike a bike section would've been so much easier if I'd have got the technique for carrying the bike on my shoulder/back sorted.
Can anyone explain or point me in the direction of web based pics or videos the correct/easiest method.
Many thanks in advance
i put the saddle on my shoulder, but it's probably not very good for it and the front wheel sometimes hits stuff and knocks you off balance. but it's the most comfortable for me
This works for me, but won't for you unless you have a reasonably large hardtail.
[url= http://farm9.staticflickr.com/8462/7991034705_6a3a6fd88f.jp g" target="_blank">http://farm9.staticflickr.com/8462/7991034705_6a3a6fd88f.jp g"/> [/img][/url]
Normally saddle on shoulder. If steep it goes on shoulders/back holding saddle nose and one handlebar.
1. Face non-driveside, lift the non-drive crank to 12 o'clock.
2. Grab both wheels by the rims at 4 o'clock (front wheel) and 8 o'clock (back wheel).
3. Lift the bike slightly, duck your head under the downtube, and rest the downtube across your shoulders.
4. Keep hold of the wheels and stand up straight
Bike should be nicely balanced, and you can walk up the massive hill. If it is balanced well, you can probably let go with one hand or the other.
Dave
You need a video or pictures of how to pick something up?
Have you considered experimenting to find the best way for you?
If you want to go faster, run alongside the bike as it will provide stability if your footing is loose and is likely to be less tiring as you arent bearing the full weight of the bike.
I was showed the downtube across the back of your shoulders method recently, as per alfabus, and it was a revelation! Once you've found the balancing point it leaves your hands free for scrambling when the going gets steep
I love this forum!! Thanks (nearly) everyone for the tips. I'll have a play around in the morning and I may even report back!
+1
It's a good reason to convert to double+bash, as otherwise you've got a chainring unhealthily close to your neck 🙂
I usually end up holding the bottom of the forks and one of the cranks at 6 o'clock, and as you say, you can usually hold it one handed.
Did the route earlier in the year, I just pushed the bike up most of it and carried it over the odd obstacle.
Took around 45 minutes but wasn't really going for any sort of speed up it.
I've already packed so I know I'll be on a Blue Zaskar wearing a red and green PlanetX wool jumper.
Really looking forward to it, even though last time round the route I was absolutely gubbed.
Although not looking forwards to the descent to KL from the WHW and back up.
I normally put a piece pipe lagging over the top tube and zip tie on
when i know i am going to do such an event.
Yep....in the old days people used to tape some pipe lagging or camping mat to the top tube and the seat tube and then later on some manufacturers even made a frame bag that fitted in the angle and gave you a curved padded corner to rest on your shoulder - I've still got mine.
This was in the days when mountain bikes were carried up then ridden ridden down mountains, not used for posing in car parks and following man-made paths round and round a forest.
carry it in way so that if you slip or trip, you can let go of the bike and not break your neck.
sticking your head through the frame is suicidal imo
some of those pics make cringe.
My way means me and the bike are fine if I slip or fall. I think the key is to getting it ballanced which I manage to do. Once walking just a light touch on the seatpost and that's all I need.
C
Post of the day for me! Why didn't you ride up too? Sounds very amateurish.This was in the days when mountain bikes were carried up then ridden ridden down mountains, not used for posing in car parks and following man-made paths round and round a forest.
