Fitted some new grips the other day, using torque wrench set to 2nm as on carbon bars. First side was fine, then on the other side the little b@st@rd rounded off straight away
Any suggestions on how to get it out? Have tried three different Hex keys so far with no joy
Drill
T15 Torx key? Maybe try tightening the screw a bit 1st too
torx bit hammered in often works, otherwise as steve writes.
T15 Torx key?
Have one of those at home, will try tonight
Do what with the drill though?
drill through where you'd put the hex key - you just need to remove the head of the bolt, so a 4mm drill should suffice (a 3mm hex head usually means an M4 bolt IIRC).
As the head is removed it will relive the pressure in the clamp and you can then remove the grip.
If it was an ali bar I would suggest pulling it off.
I take it its not the end clamp? you could hacksaw the bolt if there was enough thread showing.
If the grips don't spin, why remove it? Wait until the grips wear out, then drill it.
Whack an old torx bit in, slowly twist. I have done this way more often than I should, bit of a knack but you'll get it - I have a box of torx bits that I use for this purpose.. Small hex heads are pretty poor imo, anything over hand tight can be a pain to remove, worthwhile greasing the threads.
No need to drill. It's a pair lock on grips, you should be able to see the bold threads. Just cut it in the middle with a hack saw.
I'd use an easy out.... or if the head sits proud cut a slot in it and flat blade screwdriver it out.
It's the bolt on a set of dmr deathgrips.
Not enough space to hacksaw
I want to reposition the grip as it's not quite right for me at present (waffle bit up a bit too high)
If it's proud enough, use a drill chuck to clamp on the outside of the bolt head.
Picked that tip up from here and it's worked a treat a few times.
If it's proud enough, use a drill chuck to clamp on the outside of the bolt head.Picked that tip up from here and it's worked a treat a few times.
It's recessed unfortunately. That's a good idea if i round something proud though
Can you cut it with a dremel rather than a hacksaw, might be easier to get to it?
http://www.screwfix.com/p/trend-pro-grabit-screw-and-bolt-remover-2-pieces/21391
Saved me loads of times, cleat bolts, oven fan rusted bolts etc.
I think it is called an easy out (already mentioned by scrumfled)
Torx bit is my first step in this scenario - but I recently had a really nasty aluminium screw where even that didn't work. I put some superglue in it and glued a bit in place and that was enough to stop it skipping out. Worth a try.
As mentioned above, easy out's:
https://www.amazon.co.uk/Hakkain-Extractor-Broken-Damaged-Remover/dp/B0185PAL4Q
I used a set like this many times to remove knackered hex/torx bolts. There's also this type: http://www.ebay.co.uk/itm/small-Screw-extractor-stud-bolt-removal-tool-easy-out-set-engineering-remove-/290489660177 but i've had less success with these.
Dremel a slot- 30 second job.
