How to Remove an Al...
[Closed] How to Remove an Allen Bolt?
4 Users
Specifically any good tips on removing a couple of water bottle holder bolts that just turn in the thread of an aluminium frame without unthreading.
Impossible to get any purchase with pliers, should I drill into the bolts or is there something simpler? Thanks.
Posted : 18/06/2013 1:09 pm
It sounds more like the threaded insert is spinning within the frame?
http://www.parktool.com/blog/repair-help/water-bottle-fittings
Posted : 18/06/2013 1:12 pm
depends on how steady you are with an angle grinder... cut a small notch and flat blade screwdriver it out. Might mean sacrificing the holder though.
Posted : 18/06/2013 1:52 pm
Thanks for the advice, will give it a go.
Posted : 18/06/2013 6:12 pm
Grind a slot then use a flat blade screwdriver or flat blade bit with a breaker bar or 'T' bar. DONE!
Posted : 19/06/2013 12:07 pm
