woundering how i could reduce the oil level in my marzochi all mountain sl 2 im pretty sure this is the reason i cant get full travel. the guy i got them off tole me "ive just put some new oil in them)
pour some out? is this a trick question?
no lol. wear do i puor from? top or bottom of fork? left or right leg?
It could be more complicated than it first appears. I asked a simple question about fork oil lastnight and discovered that it might not be quite so simple.
What weight oil did the guy you got them off, put in?
not a clue. but im only getting about half travel. and this is most likely cause of the problem.
well thats what all the evidence so far points to. im only getting half travel
not even got a clue how much and wer the oil goes
..and now you're an expert? 😆It could be more complicated than it first appears. I asked a simple question about fork oil lastnight and discovered that it might not be quite so simple.
[b]What weight oil did the guy you got them off, put in?[/b]
find a service guide for the fork online Tony.
stripping and re-filling the damping oil in a fork is not complicated or difficult but you need to know oil levels/volumes and weights.
i can only find a owners manual on marzochi's website and google serch ect. and it tells you next to naff all. non of the important stuff anyways
No. just passing on the expert opinions of others... 😆
You're looking for something like this...
but obviously for the year of fork you have
nice one mate. im pretty sure these are same as mine other than mine have 20mm and these are qr. im thinking ill just empty the only out and just replace around 80% of it and see if this makes it any. if it makes it better/fixes is i know its oil levels
try that but remember too little oil and a fork may top-out from lack of damping.
And result in a silly accident. 😕
watsontony I think spellings for some of your words wrong.
Undo the top caps and dip in a cloth
cloth soaks up some fluid and hey presto
If you're going to go to the effort of pulling the forks apart, I think youd be best off replacing the fluid with the right amount of the right weight. After all, the fork is signed to run with a particular volume and type in it and if you start "fiddling" you might not ever get to the bottom of this half travel mystery.
Look via the Windwave website - they often have Marz service manuals.
As has been said - dump all the current oil, and replace with the correct volume of the correct oil....
DrP
