How to fix leaking ...
How to fix leaking digital shock pump: Lifeline, RockShox, Cane Creek, Fox.
1 Users
Lifeline digital shock pump was leaking, both from where the rubber was crimped to the 90° elbow and where that entered the pump body. This same pump is sold under several different brands.
  • Two-hole bolt may be unscrewed with needle-nose pliers. Moderate torque required to crack the threadlock.
  • Replace two 2 mm cross section O-rings. Internal diameter 8 mm. £1.73 eBay, NBR Nitrile Rubber.
  • Those new O-rings are an infinitesimally tighter fit, apply grease.
  • Encase the leaking crimp in Araldite. Any epoxy would suffice, or CT1, or OB1. Perhaps even a smear of bathroom sealant.
  • Reassemble with minimal hand-torque. The elbow still needs to swivel. Threadlock if available.
Posted : 24/11/2025 4:35 pm
I have photos to illustrate this but cannot make the links work nicely. Can someone tell me which is the image button for the postimage links, please?
Posted : 24/11/2025 4:51 pm
Posted : 24/11/2025 4:54 pm
