How much would this...
[Closed] How much would this be worth - Fox Float R that is going on ebay
3 Users
I have got a 2011 Fox Float r with low compression and low rebound set, high volume air can, in length 8.5” x 2.5” (216x 63mm)
The mounting hardware is 22mm wide with an 8mm through hole.
It is "as new" and pretty much never used as i swapped to a coil.
I appreciate it is an odd length, but does anyone have an idea on value?
Posted : 22/05/2011 8:36 am
 flow
Look on the completed listings.
Under £100 I recon.
Posted : 22/05/2011 8:44 am
i thought betwen 80 and 100 quid ish
i bought a new-old stock float R from a HK ebay trader for 60 quid a while ago. Re-sold it on ebay (after selling the bike it was intended for without fitting it, and after the original seller had probably run out of stock) for £100.
8.5 x 2.5 is hardly an odd length, IIRC that fits nomads, hecklers, Alpines, ASR7s... so a decent market out there.
Posted : 22/05/2011 5:33 pm
