How much waggle?
How much waggle?
7 Users
I bought and fitted a brand x dropper post from wiggle,tightened up the collar clamp and seat clamp bolts and found 5-6mm waggle laterally at the saddle tip
Is this normal,have I done something wrong,and can it be corrected please
Thanks
Posted : 25/01/2023 7:02 pm
They all do that - perfectly normal.
Posted : 25/01/2023 7:06 pm
 Yak
They all do a bit. Maybe yours is at the upper end of the range for a new one. Don't worry about it and remember to change the brass keys when you first service it. Then the waggle will reduce.
Posted : 25/01/2023 7:23 pm
Yep mine has done this from new. Never got any worse over the years and still works just fine.
Posted : 25/01/2023 8:05 pm
Mine waggled a bit (never bothered to measure how much) and a year later it still has the same amount of waggle (as far as I can tell). It’s never been something I’ve noticed whilst riding and I assume if the tolerances were so tight that there was no lateral movement then dropper posts wouldn’t go up and down very well (I assume).
Posted : 27/01/2023 8:51 am
Fit a shorter saddle, it'll waggle less at the tip
Posted : 27/01/2023 9:26 am
mine waggled, with a bit of fore and aft movement. I didn't like that and CRC accepted a return without hassle.
Posted : 27/01/2023 1:26 pm
