Like it says.
nothing, i don't have one :-)*
from *usefullposts.com
Turner Sultan
Sasquatch size (23")
Not built for weenyness
30lbs all up inc pedals
Niner RIP9, large, X0, reverb and crossmax wheels, 30lbs all up.
Hi
Standard Trek Superfly Large.
Guess at 27ish lbs
Steve
[i]Guess at 27ish lbs[/i]
And I'm guessing its heavier 🙂
As with any weight discussion, if there isn't a photo of it in scales then its not true and will be assumed to be heavier.
And lets include pedals lads?
17.5 inch 2012 Rumblefish elite with hope/Stans wheels & 2x10 XT/XTR upgrade.
30lbs including XTR trail pedals and original chunky Bontrager tyres
Still struggling with sub-30lbs then!
I weighed a stock S-Works Epic at 23 virtually dead, with cheap resin pedals.
My large Niner RIP9 weighs 7.4 lbs at the moment.
Don't have any pics on the scales but I do have this one of it enjoying some rare Welsh sun!
[img] http://www.rotorburn.com/forums/attachment.php?attachmentid=242300&d=1345214134 [/img]
XL Carbon Tallboy, mostly XTR (XT cassette), Flows, Reverb, Carbon bars, Conti tyres, 1x10 etc.
A smidge over 27lbs
Cotis Solaris with RLT rebas, Rohloff, ZTR Crests with Racing Ralphs, Brooks Ti Saddle, time pedals & carbon bars / seat post....27.25lbs.
Superfly 100 AL Pro w/XT pedals, 28lb 4 oz (medium)
Orange Gyro Pro, w/XT pedals, tyres switched to Bonty 29-1 2.2s, 29lb 15oz* (medium)
It's only an ounce but it's bloody well under!
Standard Trek Superfly Large. Guess at 27ish lbs
Not if it's an AL one and you haven't changed a lot of the spec.
Large Tallboy C with XT, Crests, Hope X2, 120mm Rebas, Maxxis Beavers - 27.2lbs incl pedals.
Mates Anthem x 29er (2011) was a smidge over 26lbs stock before he attached all the crap on it like Garmin, dropper post etc
Tallboy. 23.8lbs.
I can think of perhaps another lb to come of it, but it would be expensive and might compromise rideability.
tlr
What's the build in your Tallboy? Would love to get mine down close to 23lbs, is that incl pedals?
Large Turner Sultan 28 1/2 lbs
Large transition bandit, 32lb on a good day.
Custom Nicolai AM29 27.5 with pedals. 1x10. Chainguide and other beefy but light kit (which does mean yes it was not cheap)
Giant Anthem = 21.5lbs, not bad for a ally FS 3x9 setup.
Giant Anthem X 29er frame (L) with Fox Float RP23 Boostvalve
Fox F29 FIT RLC forks, 15QR thru axle and tapered steerer, 100mm travel
Giant FSA tapered headset
XTR SIS gear cable set
Shimano BB71 Press-Fit Bottom Bracket
FSA K-Force Light XC Chainset MegaExo
XTR pedals
Thomson masterpiece seatpost
Ritchey WCS Carbon Flat Bar
Ritchey WCS 4Axis Matrix Stem
Hope mono mini pro’s in Team Issue Green, Ti bolted
X0 Twist grip changers
X0 Rear mech with KCNC jockey wheels
XTR front mech
KMC SL chain
160mm Ashima rotors, Ti bolted
PG990 cassette
American Classic hubs (15mm front, QR rear)
DT Super Comp spokes
Stans Crest rims
Racing Ralphs 2.25s UST front and back
Fizik Arione saddle
Seems dubious, those tyres weigh a ton for a start! Seem to remember that discussion before though!
On who's scales is that 21.5lbs? no chance...
How do you know its not what I say? What possible benefit in the world would I have to not tell the truth?
It's the usual dubious bike weight question!
I'm sure you've hung it on some scales and they've said it's 21.5lbs. However, I would contest the accuracy of those scales, not that you're lying.
A friend had a better specced 26" carbon Anthem at 24lbs!
Plus I don't really see a ~550g 29er 2.25 RR as a ton of weight, but each to their own I guess.
I want to verify this then, don't like being in the grey. I'll borrow the scales again, weigh something to verify the accuracy, like a 10kg weight and then weigh my bike, plus my friends Superfly 100, and post the results & photos.
If I'm wrong then I'm wrong, likewise if I'm correct.
Not UST then are they...? They're more like 800g.
Well no, because as I said, the issue here isn't that you've not weighed it, it's the scales that seem dubious. You can weigh it until you're blue in the face, but it still seems a little optimistic. Perhaps everyone else's scales over weigh!
He did say he'd weight a known quantity such as a 10kg weight though, so give him a chance.
I'm highly dubious myself as well, aluminium frame, not a small size, even if that weight was without pedals I'd be surprised. Like njee, we're just saying, we've all seen better specced carbon framed 26ers weigh more than that.
Ah yes, sorry, I skim read that 😳
Be interesting to know the results!
Anthem x 29er 1 2011 are a smidgen over 25lbs stock so its possible to remove 3.5lbs surely
I'd be dubious of that too 😉
2013 Anthem 29er X3 (XL frame) straight from the shop, with pedals (M520) = 28lbs
When my box of goodies arrives from Germany in a couple of weeks it'll morph from the current Deore components into a full XT build, and I'll let you know how much weight it sheds in the process...
Disappointingly little I'll wager!
LOL, probably right, but it'll be interesting to find out...
Quoted or weighed? Because if it's quoted it'll be no pedals and silly light innertubes that pinch on the first ride, size small too. Most manufacturers are a pound over weight by the time you get a medium or large on the scales. Add 10oz-1lb for pedals and suddenly you're well past the claimed weight
There's a guy here trying to get an Anthem 29er a bit lighter - lots of info
http://forums.mtbr.com/giant/anthem-x-29er-weight-weenie-stuff-688283.html
Reading that 21.5 seems unlikely
I say this because a size medium Superfly 100 AL pro is almost identically specced to that Anthem and weighs 27lb 4oz without pedals. Are you telling me an Anthem frame is 2lb 4oz lighter than a Superfly?
Edit: meant without pedals not with
In Jota's link:
Got a stock AX29er #1 and it weighed in at 27.1 lbs
So about the same as a Superfly as I said…
My new bike is 24.5lb on the bathroom scales 😀
I would also be dubious of the weight on an ally Anthem X of 21.5lb.
I have a size L Advanced SL carbon 29er HT, Sid XX forks, Hope wheels and kit with Sram X0 10speed but 1x10 and Maxxis Ikon tyres (which are way lighter than Schwalbe UST) and it comes in at 20lb on the nose.
I hope I'm wrong as I have 29er Anthem on order but I think personally it'll be more of a 24lb touch.
I have a 2011 KHS Flagstaff that weighed 30.02 lbs. out of the box.
Although perhaps a little portly, pound-for-pound it’s fairly respectable considering the price I paid for it.
Ok, I'll admit when I'm wrong, not sure what happened before but weighed it again yesterday and it's actually 23.8 lbs. That's with a size large frame and Stans's rim tape and none UST RR evo tyres. Still a good weight I think for not trying too hard.
My mates size medium Superfly 100 with 2x 10 XX etc, and a custom wheel build weighed in at 23.3 lbs.
2012 Anthem X29er 0 in XL
RR Evo Tyres
Switch EVO Crest Wheelset
SID RCT3 Forks
1x10 with XT cranks and Zee rear mech - 11-36
Easton Carbon Bars and Post
XT Pedals
25.7lb on my bathroom scales
Tallboy C, Crests+Hope , HopeX2 Panaracer Driver (550gs), 2x10 SLX, Reba, WTB SLT saddle, Thomson stem+post, USE Carbon Bars, XTR Pedals, 26.5 Lb.
I need to borrow scales of some of the posters here before I reveal the weight of mine. 🙂
