How much contact be...
[Closed] How much contact between tyre and turbo trainer?
7 Users
Not important, a smidge or crank it until deforms the tyre?
ta
Posted : 18/01/2012 7:01 pm
I crank it until I can rotate the bikes wheel back and forth without it slipping. Tends to deform the tyre a little. If I don't do this then it tends to slip a lot and pedalling gets really jerky.
Posted : 18/01/2012 7:13 pm
As little as possible, as long as it doesn't slip.
Posted : 18/01/2012 7:45 pm
make sure you've got at least 80psi in your trainer tyre. I'd also recomend a proper trainer tyre
Posted : 18/01/2012 7:58 pm
As much as possible, crank it at 120psi in 53/23 and MTFU
Posted : 18/01/2012 8:01 pm
Not sure why you'd have less than 80 psi...
Posted : 18/01/2012 8:55 pm
 Sam
deform the tyre by roughly the amount it deforms when you sit on the bike on flat ground.
Posted : 18/01/2012 9:03 pm
I had thought that seemed a sensible amount, cheers everyone sufferfest agony awaits
Posted : 18/01/2012 9:06 pm
Enjoy the pain fellow Sufferlandrian!
Posted : 18/01/2012 9:11 pm
