If I fit an expander ring and still run 2x10 will I die...or cause a mechanical disaster?
Theres some steep hills where were going in the Alps....
I wouldnt have thought so? Having a granny ring wont require any more chain length than is required with the expander..
Id imagine it would get to the point were churning the gear would be slower than getting off and walking though.
You should be fine as long as you don't exceed the capacity of the rear mech. If you do exceed it, make sure you don't use the big ring with the larger cogs.
Failure to do so can lead to a bent frame in some cases.
http://singletrackmag.com/forum/topic/my-first-bent-frame-and-top-customer-service-from-bikemonger-and-salsa#post-7120649
kerbdog - Member
I realise that, but if I wanted to go for a walk, I`d take a dog not my bike 😉
I`d rather winch and be seated, than walk and push
