How long will it la...
[Closed] How long will it last
7 Users
Hi there never having had a half decent bike before no idea so....I ride 16 odd mile a day on the road in winter and track in summer what sort of time do components last like
chain (KMC X9SL)9 speed
Cassette (Shimano HG50 9-speed, 11-34 T)
Shimano Deore Mountain Bike MTB Chainset / Crankset M590
Shimano RD-M772 XT (long)
etc etc would you buy spare parts if you come across them new but cheap ????
Posted : 02/04/2014 8:43 pm
Depends how often you oil and clean, and the geology of where you live, some places seem to eat components more than others. It's a bit like how long does a brake pad last?
Posted : 02/04/2014 9:07 pm
well only used in the dry and use GT85 for lube keep immaculate clean
Posted : 02/04/2014 9:10 pm
GT85 is crap lube
Posted : 02/04/2014 9:13 pm
Should get a couple of years at least. Would look to a more chain biased lubricant, the GT85 is fine for cables and mech pivots, but it's not really a chain lubricant.
Posted : 02/04/2014 9:15 pm
GT85 will be OK as he only uses the bike in the dry .
Posted : 02/04/2014 9:16 pm
Ok so that answers the but spare parts if some come up then BUY THEM so what parts wear the fastest ????
Posted : 02/04/2014 9:29 pm
I wouldn't bother buying spare parts for that kit. I have roughly the same setup part for part on my full sus (I have a slightly different KMC chain) and have done for the past two years.
The Deore HG50 cassette still looks like new despite being ridden through two very wet winters. I read a post on another forum from some buy who had that cassette on his touring bike and clocked up over 4000 miles before replacing.
It wouldn't hurt to pick up a spare cassette and chain if you plan on running that setup for a long time as the 9 speed stuff is being rapidly phased out and they're going for dirt cheap now (9 speed HG50 cassettes are only around a tenner online) but in all fairness I think you'll probably want to upgrade the bike and / or whole drivetrain long before the kit starts failing.
Posted : 02/04/2014 9:37 pm
Most of my bikes are specced with the cheapest to buy steel Shimano HG50 9 spd cassettes, and Truvativ steel chain rings, a 3x9 set of these will cost under £30. Add a decent nickle Sram PC991 for £16 from CRC and your under £50 (tank full of petrol for a small car)
Your cassette/ chainrings will last easily 2 years or to 3 of these nickle coated chains if you use a dry lube - Squirt lube is what i use as it collects no crap and your nickle chain will not rust after washing. You often get sent some extra Squirt Lube if you order a few bottles.
GT85 will indeed also work fine with this set up and smells nice too 🙂
Posted : 02/04/2014 9:41 pm
Ok well just brought a chain so far for £12 so not to bad Seen the cassette for £14 and the main crank and cogs set up for £63
Posted : 02/04/2014 9:44 pm
If you shop around you will get spares for years yet (at deore/Tiagra level) no point stockpiling. Just clean and lube chain regularly, and replace cassette and chain every 2500-3000 miles IME
Posted : 02/04/2014 11:20 pm
