Hi all,
I got a pinch flat on the weekend in my tubeless back tyre and the hole was just a bit to big for the sealant to seal. I put a tube in to carry on but would like to repair it so what's the best method.
Shaun
[url= http://www.evanscycles.com/products/weldtite/tubeless-patch-kit-ec012005 ]Sticky worm thingys[/url]
Patch it from the inside using a round edged piece of old inner tube. Make sure it's absolutely clean and sand round the hole, then use plenty of weight/pressure to stick the patch on firmly.
Dental floss and superglue has worked for me a couple of times.
I use worms if the cut is far enough from the bead, or a standard inner tube patch if too close to the bead for worms. If it's a big hole I might then fill it with superglue
I've stitched with floss and glued with success in the past.
It is a bit belt and brace but I stitched with floss, superglued the area then patched it. I've found the stitching can wear away over time so the patch and glue help increase the life.
I just use Lezyne self adhesive inner tube patches. The rear tyre has 2 in there I think, and no issues.
[s]Tubeless tyres[/s] Tubes - the solution to a problem that doesn't exist
FTFY BinBins.
I might try a patch this time and I'll buy some worms to keep in the bag for future
Normal patches and/or duct tape
Worms are good for a quick fit. Use the mushrooms for a permanent fix: http://www.ebay.co.uk/itm/12-TYRE-PUNCTURE-REPAIR-WIRED-3MM-SMALL-HEAD-PLUG-PATCH-MUSHROOM-/131208504777?hash=item1e8ca2e5c9
as creamegg says,
that sticky worms string stuff is ace.
I fixed two goping holes in the sidewall of my fatty tyre a few weeks back & has run tubeless perfectly since. Done 400km on it since fixing so quite happy.
Only ever had one cut that wouldn’t heal itself.
I glued a patch on the inside in the same way you would glue a patch on the outside of a tube.
Only tricky bit was trying to keep the spaff in there and hold the patch in position, with a tube I just put a peg on it but inside the rim that is still full of spaff (wiped away around the gash!) is difficult.
A bit of fumbling about and it was sorted.
Nobeer, bit of a fail given the OP himself had to rely on that flakey obsolete technology to get home. As have all the mates I've ridden with who've rolled tubeless tyres off the rim, or had punctures that didn't seal and sprayed latex over his bike and kit.
For every flat I've had in the last 5 years I've had a tubeless riding mate suffer a mishap that took a tube to resolve.
Worms for external, standard innertube patch for if you take the tyre off. I'm not the biggest worm fan myself but it might be user error to be fair.
I cut up an old tube, and then superglue it to the tyre. Trying to seal a bead hole is impossible without patching.
