How do you measure ...
[Closed] How do you measure the length of a seatpost?
7 Users
 H
Do you measure the length of the post to the bottom of the clamp?
I have just bought a new frame and require a 350mm seat post. I then bought one and the length of the post upto the clamp is 327mm which is too short. Are seatposts usually measured to the rails?
Thanks very much!
Posted : 02/09/2010 10:58 am
bottom of post to rails usually though as ever there'll be some companies that do it differently.
Posted : 02/09/2010 10:59 am
Ooh, never really thought about that. I would have thought it's the maximum length that can be inserted in the frame. I could well be wrong....
EDIT: Just measured my Thomson, which is 330mm from end to seat rails. Others may measure up differently.
Wot clubber said
Posted : 02/09/2010 11:01 am
 H
Hindsight is a wonderful thing 😉
I knew I should have asked on here first - Thanks for your help!
Posted : 02/09/2010 11:05 am
 br
You'd have been better buying a 400mm anyway, as it sounds like you'll still have too little in the frame.
Posted : 02/09/2010 11:22 am
Yep, it's length of whole post, not to minimum insertion mark.
I'd say the frame is maybe a touch too small for you if you need 350mm of post sticking out!
Posted : 02/09/2010 11:49 am
 H
Sorry i shoudl have been a bit clearer - I dont need 350mm sticking out!
The frame takes a 30.9mm post so lined up a 27.2mm post from another bike and decided that a 350m post would be ideal. However I was measuring to the top of the post not the rails. The 'missing' 23mm from my measurements therefore puts the post above its max.
Posted : 02/09/2010 2:02 pm
If you're using a shim then the length of the post below the shim is almost irrelevant as it won't be in contact with the seat tube.
Make sure you use a shim that drops as far down into the frame as possible.
Posted : 02/09/2010 2:05 pm
