How chunky is a chu...
[Closed] How chunky is a chunky monkey?
9 Users
I'm currently running a Bonty 29x2.3 tlr on the front with Rebas on a 42mm rim, but clearence is miniscule. Anyone running a monkey with Rebas?
Posted : 09/12/2013 8:39 am
42mm rim? Blimey, what's that? I have a Monkey on a Flow rim run in in Revs with loads of clearance
Posted : 09/12/2013 8:43 am
It is a nimbus Dominator from when I ran rigids. The Bonty tyre is flipping huge!
Posted : 09/12/2013 8:51 am
I'll offer one into a Reba for you later if you don't get a satisfactory answer on here.
Would be on a Crossmax rim though if that's any good?
Posted : 09/12/2013 9:04 am
Not running one with Rebas so can't comment on room but they are a crackin tyre. Loads of grip in the wet on rocks. They are big but they're great.
Posted : 09/12/2013 9:16 am
ran one last year on a mavic x517 rim- it was huge on that and not great clearance - so on a 42mm rim I can't see it fitting!
Posted : 09/12/2013 9:19 am
It is more of a height, than a width issue, I wouldn't have thought the wide rim would make it taller?!
Chakaping, thanks mate.
Posted : 09/12/2013 9:40 am
I run one on Crest, it barely fits under my rev forks, so much so that I cant even run a mucky nutz.
Posted : 09/12/2013 9:50 am
as monkeys go they are this kinda chunky
on my 721 rims they are very tight on marzocchi 44s
Posted : 09/12/2013 9:55 am
Thanks all, looks like it will be a no for the fat monkey then.
Posted : 09/12/2013 9:59 am
very tight at the top of the brace
Posted : 09/12/2013 12:36 pm
29er Chunky Monkey on a P35 rim fit into my Rebas with a small amount of clearance.
Posted : 09/12/2013 1:00 pm
 br
[i]I run one on Crest, it barely fits under my rev forks, so much so that I cant even run a mucky nutz. [/i]
Odd, as mine (2.4 super sticky version) fits fine with the same setup - maybe you've not the Mucky Nutz fitted right?
As a reference, it was 9mm taller than the single-ply DHF Minion it replaced.
Posted : 09/12/2013 1:05 pm
Possibly, however its that close that leafs etc sometimes build up in the space.
Posted : 09/12/2013 1:39 pm
