How can I find out ...
[Closed] How can I find out if frame/fork is bent after a crash
5 Users
I slammed straight into a rut yesterday and got catapulted over the bars. It was a heavy impact for the frame and fork to take square on and now I’m not sure if they are bent backwards or not.
Once I got back on the bike the forks felt slightly taller and the head angle seemed steeper. This might be my imagination.
Is there a way to check either are bent?
Frame is Pace RC627
Fork is Fox 36 ebike version
I took the fork off and laid it flat on a table. Then I used a spirit level to check the steerer, stanchions, and legs where all inline, which they were. This is all I could think of beyond buying the same frame and fork and putting them side by side.
STW please advise
Posted : 08/09/2019 7:28 pm
Is there any sign of the paint falling off around the top tube/downtube?
I very much dought that you've bent a 36 ebike fork and lived to ask the question.
Posted : 08/09/2019 8:24 pm
You'll usually get paint cracks as a tell tail. TBH MTB's are exceptionally strong, and I doubt it's bent. More likely to pringle a wheel first.
PS instead of 'how's the bike', how are you ? - superman impressions are painful.
Posted : 08/09/2019 8:38 pm
I’m ok, bruised ribs, sore neck, and probably a bit of concussion. I did see a lot of stars, it was like a cartoon.
I haven’t checked the frame too closely yet only the forks.
Posted : 08/09/2019 9:04 pm
I've bent two frames like that, both had noticeable bulges under the downtube at the joint with the head. No gussets on either though, I also think it's unlikely an OTB would bend a modern mountain bike frame.
Posted : 09/09/2019 3:22 am
TheGhost
Member
After reading a recent thread on here about that, it might be worth getting checked out bud.👍
Posted : 09/09/2019 4:16 am
