How buckled does a ...
[Closed] How buckled does a wheel need to be before it's worth getting it trued?
5 Users
My rear wheel has got a wobble in it that's probably between 5 and 10mm. Worth getting fixed or just forget about it?
Posted : 23/09/2014 10:27 am
It'll be easier to fix now. 10mm is a lot IMO
Posted : 23/09/2014 10:28 am
at 10mm I'd be worried it was beyond saving...
Posted : 23/09/2014 10:30 am
Right then looks like I'd better get it trued in that case 🙂
Posted : 23/09/2014 10:33 am
 Yak
I get the spoke key out at 1mm. Do it now, as long as the rim isn't knackered elsewhere.
Posted : 23/09/2014 10:34 am
The further out of true a rim is, the further out of balance the spoke tensions will be. This is what makes the wheel weaker. It's best to get that run as close to straight as possible without spoke tension.
Personally I'd loosen everything off, get the rim in a soft jawed vice and heave it as close to straight as possible before re-tensioning it. At 5mm deflection Is probably risk just pulling it straight unless I had time on my hands.
Posted : 23/09/2014 11:18 am
