How Accurate is met...
[Closed] How Accurate is metcheck?
21 Users
Apprently, from 6pm today, its not going to get above freezing fro over a week.
Can I look forward to rock solid trails all next week?
Posted : 24/11/2010 3:11 pm
any weather report cannot be trusted totally beyond two days due to the chaotic behaviour of weather systems. that said if they know the weather system is coming from a particular direction its easy to determine the temperatures we might encounter.
Posted : 24/11/2010 3:51 pm
Not very IMHO.
Much prefer to use the MET office website.
Posted : 24/11/2010 3:54 pm
slightly OT: isn't MetCheck run (or used to be run) by a convicted paedophile?
Posted : 24/11/2010 3:56 pm
highclimber - Member
Where the hell do people get this info from?? 😕
Posted : 24/11/2010 4:03 pm
Google 'Andrew Bond Metcheck'
Posted : 24/11/2010 4:05 pm
It's about as accurate as astrology, like all weather forecasts
so a sharp frost tonight, then all thawed by saturday 🙂
and just read up about Andrew Bond. Hmm, hope he doesn't get any revenue from metcheck..
Posted : 24/11/2010 4:07 pm
I use accuweather UK / BBC and is usually a bit more spot on 🙂
Posted : 24/11/2010 4:14 pm
Reckon Metcheck OK for a couple of days out but then can be wildly inaccurate from experience; best bet I`ve found is look at Met Office + MWIS + synoptic maps and go for a consensus view, and tehn treat with care! Although some weather patterns are better forecast than others and teh forecast developing high in central atlantic, which will pull down Ntherly winds, probably has a higher forecast certainty than tracking depression tracks across UK, position of which can greatly affect wind directions and rainfalls
Posted : 24/11/2010 4:21 pm
http://xcweather.co.uk is worth a look too
Posted : 24/11/2010 4:28 pm
It's called "The News"
Posted : 24/11/2010 4:34 pm
I usually have a look at Metcheck to see how wildly innacurate they can be.
Posted : 24/11/2010 4:46 pm
it's metcheck that does 200mph winds every now & then isn't it ? (maybe only on the longer ranges IIRC)
Posted : 24/11/2010 4:55 pm
Just found this...
http://www.singletrackworld.com/forum/topic/metcheck-owner-in-prison 😐
Posted : 24/11/2010 4:59 pm
This accurate:
Posted : 24/11/2010 5:03 pm
From Until Temp Feels UV Rain Cloud Dir Speed Gust
15:00 17:59 12 °c 9 °c 0 2.7 mm 97 % 4 mph 4 mph
18:00 20:59 9 °c 1 °c 0 2.9 mm 99 % 122 mph 146 mph
21:00 23:59 7 °c -2 °c 0 13.7 mm 99 % 93 mph 111 mph
forecast for 5th November 2010 - admittedly it was a 3 day forecast
but the hurricane failed to appear
Posted : 24/11/2010 5:05 pm
haha metcheck is always good comedy!
apparently it's -14C outside, with -22C windchill
My thermometer say +4C right now. SO it's accurate to within 18C 😉
not sure if I have screenshot of the one with 320mph winds (might be another thread on here somewhere).
Posted : 24/11/2010 7:21 pm
They all use the same met office data anyway don't they?
Posted : 24/11/2010 7:25 pm
metcheck is supposed to use a different model
ie the one not goosed by all the climate change assumptions
I find metcheck a lot more accurate than BBC, but not perfect
R4 are supposed to be doing a experiment to actually see who is the most accurate
alternatively 80% + of the time the weather tomorrow is the same as today
Posted : 24/11/2010 7:30 pm
Metcheck uses US weather models.
 IanB
http://yr.no is a good weather website. Based in Norway, but good coverage for the UK - presumably using different data (albeit of the same weather systems) to the UK's met office.
Posted : 24/11/2010 7:33 pm
 rhys
It's actually pretty good for Cornwall, not bad considering it's a tiny narrow strip of land
I use http://www.wetterzentrale.de/topkarten/fsavneur.html which is a german weather forecast, only prob is it is all in german. It is really good for a more longer term forcast however as said above unless it is really obvious they are never goin to terribly right for anything more than a couple of days in advance.
Posted : 24/11/2010 7:47 pm
Some years ago (approx. around 2004), when i was very much into winter climbing, all the major channels were reporting heavy snowfall predictions in that November made by Metcheck. I sharpened the axes and crampons in anticiption, only for it to be a complete load of tripe. I've never forgiven him/them for it. Was glad to hear of him being conviced a few years ago and i've never experienced many people say good things about Metcheck forecasts since. My opinion is skewed in the -ve, but I wouln't give them the time of day. Stick with Metoffice, MWIS (mountains), XC weather (wind speeds), weatherline (specifically the Lake District) and the BBC, they are all effectively Metoffice forecasts, but with some local slight variations, more detail and/or specialist for specific sports.
Posted : 24/11/2010 10:10 pm
