Hoses into GRX leve...
Hoses into GRX levers: heck am I going wrong?
6 Users
3 Reactions
I have GRX810 levers, and 'Zee SM-BH90' hose kit.
I'm following the instructions to the letter: barb in, then olive, then flare nut.
Can I get the nut to tighten down and hold the hose? No, I can't. I thought I was there, but as soon as I started to bleed the system, fluid immediately pissed out from around the connection and flare nut.
I'm beginning to wonder if I have the correct hose kit?
Anyone any experience installing GRX brakes able to offer any advice or insight?
(I'm using RX4 calipers, and the connections at that end went like a dream.)
Posted : 06/04/2023 10:32 am
Does your flange bolt look like this?
Posted : 06/04/2023 10:36 am
Hmm. No.
Well I'd start by getting one of those first 🙂
Part # Y8RD02000
(if you buy the levers separately they don't come with one)
Posted : 06/04/2023 10:37 am
Come to think of it - my flange nut seems to have no flange.
Posted : 06/04/2023 10:38 am
did I need this one?
https://www.sjscycles.co.uk/brakes/shimano-smbh90jk-disc-brake-hose-straight-connection-black-rear-1700mm/
Posted : 06/04/2023 10:39 am
Yes, but as you've already got a hose just buy the flange nut
Posted : 06/04/2023 10:40 am
Yeah, I knew I'd done something stupid here.
Thanks for the quick answer. 🙂
Posted : 06/04/2023 10:43 am
simondbarnes reacted
I've just fitted GRX810 levers. The reservoir/bleed screw is larger than the old 5800 levers I removed, you'll need a different bleed kit. I got one from Epic Bleed Solutions that has an adaptor that fits both. I also got litre of mineral from halfrods. Used about 30% of it.
They are a pia to bleed. Saying that, the Ultegra caliper was fine but the new Grx810 caliper took work. Good luck
Posted : 06/04/2023 10:59 am
Also check that the levers don’t already have olives in behind the nut. My ultegra levers did, and I nearly ruined them by trying to screw another in there.
(These were part of a groupset from Merlin - I’m guessing OEM)
Posted : 06/04/2023 11:04 am
I’ve just fitted GRX810 levers. The reservoir/bleed screw is larger than the old 5800 levers I removed, you’ll need a different bleed kit.
I've just bled some GRX 600 and realised this.
Got a £4 adapter off Amazon, so it takes the normal bleed funnel.
Posted : 06/04/2023 11:09 am
Shimano decided a new M9 fitting with a flange would be better than the M8 on previous shimano brakes
Posted : 06/04/2023 6:03 pm
Pacey reacted
