Hose/cable guide th...
[Closed] Hose/cable guide that holds the cable away from the frame?
7 Users
 Bez
Many years ago someone kindly sent me a widget they'd made: a cable guide which attached to eg a rack boss with a simple bolt, and which held the cable/hose on an arm an inch or so long, so that it was clear of the frame.
I'd like to get something similar to attach to a lowrider boss on a carbon road fork to prevent rubbing. Googling for this is proving tricky. Does anyone know of anything? (Have I even explained it clearly?)
Thanks 🙂
Posted : 12/01/2016 11:06 am
What about something like this with a spacer between the hole on the clip and frame?
Posted : 12/01/2016 11:38 am
 Bez
Hmm. Might work; I've got some of those at home and I could try some bolts and spacers from the stockpile. Not sure whether it'll get the cable clear enough of the fork but it's worth a punt.
Posted : 12/01/2016 11:50 am
pop a zip tie through a cable ferrule then round the hose, will make it stand off the frame
Posted : 12/01/2016 11:55 am
 dexa
Anyone have a picture of the zip tie / cable ferrule option. That might help with some of my cable issues.
Posted : 12/01/2016 11:59 am
Basically make the hole bigger, feed the cable tie down the ferrule, through your existing cable guide back up the ferrule then round the cable. It just stands there as a spacer
Posted : 12/01/2016 12:01 pm
I've used a little bit of plastic tubing for this in the past - like this:
http://singletrackmag.com/forum/topic/carbon-fork-brake-hose-protection
Posted : 12/01/2016 12:21 pm
 dexa
Many thanks for that, I understand and that's a very good idea.
Posted : 18/01/2016 5:45 pm
I do the cable ferrule thing on the headtube, cable tie around the headtube just above the lower headset cup, it goes through a ferrule, round the cable and back through, then around the headtube to the other side, same again, add another cable tie if its too short, and then tighten up.
Cheap ferrules are better as with the sealed type you lose some length once you've chopped off the bit with the O ring seals where the inner cable goes in.
Posted : 18/01/2016 5:54 pm
Search Hose Guide in Cycling on eBay, I've used items similar to;
BBB HydroGuide
JAGWIRE Stick on Cable Housing
A2Z Hydraulic Hose Cable Holder
Posted : 18/01/2016 6:32 pm
