Hose shortening new...
[Closed] Hose shortening new brakes - is a bleed required?
3 Users
As above, on Shimano SLX.
Posted : 20/09/2012 10:15 am
No.
Pop out the pads
Push the pistons out a bit by pulling the lever (not too far).
Unscrew hoses at the lever and snip
Connect then back up with the new olive and insert
Undo the lever fill cap/screw (depending on version)
push the pistons back in
pop the fill cap/screw back in and clean up any oil.
Job done.
Posted : 20/09/2012 10:51 am
Thanks phinw
Posted : 20/09/2012 10:56 am
As phinw says, no bleeding probably required but make sure you have the spare olive and insert to hand. Having to order them from CRC after you've chopped the hose probably needs a bleed 😳
Posted : 20/09/2012 12:06 pm
