Hope TRex 40t
[Closed] Hope TRex 40t
3 Users
Will this work on a 1x9 set up with a short cage mech.
Posted : 31/03/2014 6:24 pm
Nope, not without a bodge.
Designed for 10 speed, remove the 17T cog if using Shimano XT mech.
Posted : 31/03/2014 6:36 pm
Should work if you can tweak the spacing, might still work without:
9 speed spacers = 2.56mm
10 speed spacers = 2.35mm
The t Rex looks to have a wide base from what I can tell effectively integrating that spacer, so you need to find a way to add ~0.2mm, time to break out the tin snips and old coke cans methinks...
Posted : 31/03/2014 6:52 pm
