As per title the piston has started sticking in when lever pressed, anybody else had this? Will I get away with ordering a piston or will I need more parts?
[url= http://www.chainreactioncycles.com/ca/en/hope-tech-master-cylinder-piston/rp-prod41873 ][/url]
If not will a tech 3 lever work
Mine wasn't sticking but had a bit of stiction. I just dissembled that part of the lever, lubed up the piston seals, rebuilt it, bled it and that sorted it.
I've just had a look and it's getting worse. I had to bleed it the other week and what I thought was 5.1 fluid turns out to be rockshox hydraulic oil which I'm guessing has swelled all the seals, looks like a full rebuild so I will have to find a full kit............ That will teach me to concentrate a bit more
Mmm, That could be the problem. Probably best to swap out the calliper seals whilst your at it, or speak to Hope and ask them to rebuild/service it, I think it's about £40 and that includes pads.
Wow that's a good price, I'm in Canada though so will do it myself, parts are pretty cheap actually now I've managed to find them all
