Hope Tech 3 Shifter...
[Closed] Hope Tech 3 Shifter mount
7 Users
Confused!
What adaptor do I need to fit a OneUp dropper lever to my Hope tech 3 lever?
What Lever do I buy? the 'I-Spec II' or the 'I-Spec EV'?
Thanks
Posted : 10/08/2020 12:18 pm
Sram left is what you want. Thats the 'native' fit for a One up lever. Everything else is an adaptor on an adaptor I believe.
Part code HBSP325L
Posted : 10/08/2020 12:20 pm
Tech 3 levers are i-spec II compatible with the addition of a small nut from Hope.
By that, I mean that's how I've attached a Bikeyoke triggy to one set of tech 3 levers, and a Wolftooth to another.
Edit. I'm wrong. It's i-spec B that fits to Hope with just the nut. I-spec II is an adaptor plate. Both my dropper levers are i-spec B and bolt straight on.
Posted : 10/08/2020 12:21 pm
Is it not the SRAM MMX/Matchmaker style one you need?
Posted : 10/08/2020 12:22 pm
I asked Hope, OneUp and on here and didn't get a definitive answer, so watching with interest.
Posted : 10/08/2020 12:25 pm
Cheers folks, I think Ben has the correct answer, as far as I can tell. All a bit confusing!
Posted : 10/08/2020 12:31 pm
ahh they have sorted that with V2? I know the V1 had no way of mounting to a hope tech lever without adapter on adapter as mentioned. For this reason I went wolftooth
Posted : 10/08/2020 1:57 pm
I've been running a oneup v1 lever with sram mount on tech 3s for six months or so. Just requires a bit of filing on the hope adapter. V2 lever looks a much better fit.
Posted : 10/08/2020 2:13 pm
