Hope Sticky Piston ...
[Closed] Hope Sticky Piston Lube
7 Users
Struggling to find the Hope/Hunter's one in stock anywhere, but I remember someone on here had found the same lube with different branding.
No luck on search - can anyone remember?
Posted : 02/06/2020 1:55 pm
It’s just a silicone grease, as used by plumbers. Silicone spray seems to work just as well, but is a bit messier.
Posted : 02/06/2020 2:05 pm
I can live with messy.
Tried a drop of brake fluid but still got a couple of sticky ones, wasn't sure about spray
Posted : 02/06/2020 2:08 pm
If your Huddersfield/Halifax based, you're welcome to borrow it.
Available here;
https://www.ebay.co.uk/itm/Hope-Silicon-Lube-/363009776760?_trksid=p2385738.m4383.l4275.c10
Or as above, silicon spray should be OK. If you have a straw to direct spray/limit mess.
Posted : 02/06/2020 2:13 pm
Appreciate the kind offer, but I'm not even in the UK đŸ™‚
Will try spray for now. Thanks
Posted : 02/06/2020 2:32 pm
Hunter SC960
widely available from plumbing supplies places
Posted : 02/06/2020 2:55 pm
If using a spray just spray it onto a surface (into the lid of the tin?) and use a cotton bud etc to smear it around the pistons. Then push the pistons into the caliper and wipe away any excess.
Posted : 02/06/2020 3:15 pm
I am using dow corning silicone grease. Best to check with Hope first though.
Posted : 02/06/2020 10:13 pm
In stock here. I got mine from them a couple weeks ago. Nice fast service from them too.
http://www.bikegoo.co.uk/components-c8/disc-brake-spares-c11/hope-silicone-lubricant-p519/s1194
Posted : 02/06/2020 11:56 pm
