Does anyone use them on there road bike?
I'm in need of a new set for new wheels. Thought I mite jazz it up and a different colour. Blue.
Salsa are better, in my opinion.
Shimano, Campagnolo, Fulcrum or anything with a closed cam only for me.
Superstar ones are about half the weight and almost half the price.
Work fine, a little more subtle ime.
I use them. Blue too! It's how I learnt that the hub's were different widths; I googled to see why there was threaded skewer coming out of the non-cam side.
They hold the wheel in tightly and have never come loose. I think Salsa are over-rated. The sweet spot for the threaded side so the lever gets the right tension is tiny!
Not sure what blingy ones I'd recommend (like I said, my HOPE are great) but for non-bling Shimano every time.
I wouldn't use Hope skewers to barbecue a kebab, let alone hold my wheels on. (Yes, I've had some bad experiences with them!)
Closed cam skewers only for me too. Hope make many good things but quick releases aren't one of them
Hope skewars are utter garbage, and i have hope almost everything,
Hope skewars have come loose too many times for me so i binned them. THEy changed the design i tried them again. Still garbage.
My deore skewars work as well as my xtrs and ill buy them long before i go near blingy coloured ones.
What does closed cam mean?
Superstar where from?
I use them on my road bike.
Had some spare ones kicking around from an old bike build.
No issues at all with any of mine.
Got an old ninety's titanium one doing great service on the back of the hardtail at the moment!
Max
Use them on my road bike, but road bike is disc brakes with same hub dimensions as a mountain bike. Hope in blue looks great on it.
Hope Quick releases are great have them on all my bikes which don't have bolt through been using them ever since they came out never had a problem with them and they look great brought some orange ones the other day look trick put them on a gravel bike.
Hope skewers are up there with their grips in terms of "what were they thinking".
I use them on my road and they've been faultless.
Look stealthy in black!
Skewers shall be Shimano. Or DT RWS.
That is all.
Closed ca, more properly called internal can, have the lever turn right angles through the end. The internal bit is can shaped, most cheap, or expensive, ones have an external can grinding on a cup shaped lump. You won't improve much on the cheapest Shimano one made sort from finish maybe.
Mr Campagnolo got it right decades ago.
Have blue hope on my mountain and road bike, never have come loose, look nice but my pal bought some planet x ti ones that weigh a gnat's fart, bit of a Tune rip off but much cheaper.
Skewers shall be Shimano. Or DT RWS.That is all.
+1
I have some nice Hope MTB skewers on a road bike, they worked fine on a MTB for 5 years and they've been fine on a road bike the last 2 years.
Superstar.com
Ive used hopes for years, never had them come loose, have heard many people mention it tho.
Tbh, decent shimano are at least as good as anything else out there.
TBF, I've not seen so many bad reports on the newer version (as pictured above). The old "ball-ended" ones were atrocious.
The ball ended ones were both kack and painfull, you had to do them up that tight you couldn't get behind the lever to prise it off, I've got the ones as pictured above, never come loose in several thousand miles?
I'd like some Ringle ones though for that old skool look
