Hope RS4 weirdness
Hope RS4 weirdness
4 Users
2 Reactions
Just picked up some new to me Stans Grails on RS4 Hubs. We've got 5 pairs of pro 4s and a set of pro2 evos but RS4s are new to me, and they are fitted with the 2 pawl HG free hub.
I've noticed once fitted that I get the usual hope noise when starting to freewheel, but then the hubs go nearly silent when coasting. The hubs seem to engage fine when I start pedalling again, and then are noisy again once I stop but then go quiet again very quickly.
There's a little bit of grease in the ratchet system but I don't think an excessive amount.
Is this what happens when the pawl springs need changing? I've pulled the free hub off and the springs seem to snap back fine when I push the pawls down with a finger. Am I about to die in a ball of flames if I ride them anymore?
TIA as ever
Posted : 26/09/2024 1:38 pm
My rs4 give a constant, gentle tick, tick, tick when freewheeling.
Posted : 26/09/2024 3:15 pm
I’m slightly disappointed with my RS4s. I’m used to BIG LOUD Hope hubs and the RS4s have a subtle click. If I’ve spent this much money on poncy hubs I want everyone to know I’ve spent this much money on poncy hubs.
Otherwise my RS4 / 20Five wheels are very good.
Posted : 26/09/2024 7:02 pm
dyna-ti and dyna-ti reacted
I'd start by cleaning out all the grease - I suspect it's gumming them up a bit. I use 75/90 gear oil in mine, no issues with longeivity, plus easier to clean them out every once in a while,
if you want more noise, it will then seem louder, but if you want even more noise you can use Pro4 freehubs in them.
Posted : 27/09/2024 8:56 am
Thanks all.
I'm not too fussed about them being noisy, based on the above maybe I need to adjust my expectations of how noisy they should be!
Posted : 27/09/2024 5:57 pm
