Hope Race EVO Shift...
[Closed] Hope Race EVO Shifter / Dropper Adapters
6 Users
Like e4's, don't see the need for tool free adjustments (honestly when do you really need to change the lever angle mid-ride; and even if you did in such a hurry that you couldn't afford to get a 3mm out?).
Can't for the life of me find any adapters to fit shimano or sram-style shifters and dropper levers to them. Have they just stopped being made? If so, this wastes all the advantage of the weight loss of a race lever because now you have to put a separate clamp on your bars (which I find offensive anyway).
Posted : 12/02/2022 3:38 pm
Wolf tooth do some for Magura levers, they mate OK with E4s, they replace the c-shaped clamp, suspect they would work OK with Race too.
Posted : 12/02/2022 4:00 pm
@honourablegeorge
Race shifter mounts split on the horizontal (top / bottom) whereas tech mounts split on the vertical like magura. Sadly they don't work together.
Posted : 12/02/2022 4:34 pm
Maybe but I doubt it.  Ask a friendly bike shop if they can order them?  The Race Evo was always the rarer light weight option and now it has been superseded by the XCR I don’t think you are going to find much in stock.  Hope are pretty good at keeping stuff available though
Posted : 12/02/2022 4:53 pm
Race LH shifter mount is in stock at Wiggle. Can this be used with a dropper?
Posted : 12/02/2022 5:35 pm
I may have a R/H SRAM one spare if you needed it.
Kind Regards,
Max
Posted : 13/02/2022 10:38 am
 drew
If @continuity doesn’t want it @Turnerfan1 I’d be interested.
Posted : 13/02/2022 11:30 am
@turnerfan1 yes - inbox me?
Posted : 13/02/2022 11:51 am
PMed you continuity.
Regards,
Max
Posted : 13/02/2022 11:59 am
Found some Shimano 10 speed ones also if anyone is interested?
Regards,
Max
Posted : 13/02/2022 12:10 pm
Turns out none of these are bodgeable with any of the new 11-12sp shimano mounts. Either those linked by turnerfan or the "xtr" ones from wiggle (bought some, will return).
Sram only or wait for XCR's. Shame, as I hate the tech 3 lever but the race is lovely.
Posted : 14/02/2022 4:12 pm
