Are the Hope tech [u]leavers[/u], and the Hope tech EVO [u]leavers[/u] on the master cylinder the same?
Thanks
No I think the leverage is better in the EVO but might be back compatible.
The EVO has a revised pivot point and uses a roller on the cam rather than a sliding interface.
I've got both. I struggle to see the change in pivot location but the roller is well worth having and is backwards compatible.
Only loosers use hope breaks. 😡
LsD, do you mean "losers"?
and brakes lol
looser lsd 🙂
No!! I pacifically said Loosers. 😡
[i]No!! I pacifically said Loosers[/i]
You is tick innit!! Or does you has a speach & spellin insediment?
Pretty sure LsD is taking the mick because the op said leavers.
