Hope QR to X12
[Closed] Hope QR to X12
3 Users
I have just received a new Hope Tech Enduro Rear Wheel. The wheel as received is 'set up' for QR however I need to make it so it fits x12 (142x12). What do I need to do?
Cheers.
Posted : 02/09/2016 12:34 pm
You will find the adaptors in the box. You need to remove the QR end caps off the hub (they simply pull off, but will be quite stiff) and pop on the 142x12 end caps.
Posted : 02/09/2016 12:42 pm
End caps pop off and can add 142x12 end caps.
I had to get them from CRC as the shop I bought the frame and wheels from forgot to mention the end caps.
[Edit, I got the 15mm end caps for the front wheel but the rear wheel only had a spoke and sticker in the box.]
Posted : 02/09/2016 12:44 pm
