Hope Pro4 FH Boost ...
[Closed] Hope Pro4 FH Boost conversion
3 Users
Evening all.
Quick question ......
I have a Pro 4 front hub in std QR fashion.
Looking at a Boost fork.
I see you can get a Hope converter that looks to just sit on the NDS replacing a regular 15mm spacer.
My question is how much tweaking is needed to get the wheel centred again?
Is it in the "normal" tolerance of what is usual re nipple tweaking 😆 😳
Posted : 10/12/2017 6:33 pm
Yep.
As long as your wheel hasn't been built with spokes that're to short it'll be fine.
I've used the same converter on two different front wheels and it's a ten minute job to true the rim across.
Also trued a rear wheel across for a 6mm offset frame.
Posted : 10/12/2017 6:37 pm
Cheers Stu - now to buy a fork .....
Posted : 10/12/2017 7:44 pm
There is an adapter that needs no truing, it's two end caps and a spacer for the rotor. Not made by Hope but will fit Hope.... just can't remember it right now...
Edit: it's from [url= https://www.mrpbike.com/better-boost-adapter-kits/ ]MRP[/url]
Posted : 11/12/2017 12:03 am
