How can I tell if my rear hub is an Evo?
The hub itself is just marked Hope Hoops
Posted : 24/07/2013 5:38 pm
Mine are marked on the other side of where it says hope hoops. If you really want to be sure, look down the rear axle. If you just see axle, it's an EVO, if you see bearings, it's the older one.
Posted : 24/07/2013 5:40 pm
Not an Evo then. Mine has Evo stamped on it so yours must be the regular ones.
Take the skewer caps off an measure the diameter of the axle.
If its 12mm it's an EVO.
Posted : 24/07/2013 5:45 pm
